BGP route -map
Steven Williams
Level 4
Level 4
If I create a route-map that blocks routes being advertised to a neighbor (outbound routes), will I still see those routes in the local routers show ip bgp table?
Vishesh Verma
Yes, a route-map applied to a BGP neighbor only filters the advertisements. You would still see those routes in local router's BGP table.
-Vishesh
Vishesh Verma
-Vishesh
If you want to see the local routes use show ip bgp
If you want to see what is advertised to the neighbor use show ip bgp neighbor advertised-routes
This is a good document with some case studies of BGP -
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a00800c95bb.shtml
-Vishesh
Jon Marshall
Steven
As Vishesh says you will still see them. This is because BGP has already run through the best path selection on all the routes it has received from BGP peers an placed them in the BGP table. So your route map is simply filtering what is then advertised to other BGP routers but they are still in the BGP table.
Jon
