BGP Route
Hello Experts,
I have an query for the below. Please correct me if I am wrong and provide me an solution.
When I had given an command :  show running-config | sec bgp,  the output shows as follows:
(Taken one network segment for sample)
address-family ipv4
network 10.180.0.0 mask 255.255.0.0
Questions:
1. As per the BGP theory any route advertised locally it need to be routing table as below:
Network Next Hop Metric LocPrf Weight Path
*> 10.180.0.0/16 0.0.0.0(local route).
But when I given the command: sh ip bgp | i 10.180.0.0 in router it show the output as below:
*> 10.180.0.0/16 10.242.31.129 0 32768 i
sh ip bgp 10.180.0.0
BGP routing table entry for 10.180.0.0/16, version 3532426
Paths: (1 available, best #1, table default)
Advertised to update-groups:
879 890
Refresh Epoch 1
Local
10.242.31.129 from 0.0.0.0 (10.242.0.88)
Origin IGP, metric 0, localpref 100, weight 32768, valid, sourced, local, best
rx pathid: 0, tx pathid: 0x0
2. Could you please conform why the next hop is showing as different, even though it was advertised locally in my router.
Sathish
Jon Marshall
Can you post the output of -
sh ip ro 10.180.0.0 255.255.0.0
Jon
Hi Jon,
Please find the output:
sh ip route 10.180.0.0 255.255.0.0
Routing entry for 10.180.0.0/16
Known via "static", distance 1, metric 0
Advertised by bgp 65535
Routing Descriptor Blocks:
* 10.242.31.129
Route metric is 0, traffic share count is 1
879 890
Refresh Epoch 1
Local
If this is not directly connected, it will not appear as you need.
Jaderson Pessoa
*** Rate All Helpful Responses ***
