02-22-2018 09:39 AM - last edited on 03-25-2019 03:50 PM by ciscomoderator
So I am posting this because I can't seem to wrap my head around it. It is the first time I have ever seen something like it before and while I will admit that my experience is limited I was not aware that this was possible or how it works. I am using different ips than what is on my network but everything else was cut and pasted. Please see below. Can someone explain why or how it works with the router ID being the same as the neighbor address. I didn't think this was possible.
router bgp 65102
bgp router-id 10.168.88.106
bgp log-neighbor-changes
network x.x.x.0 mask 255.255.255.0
neighbor 10.168.88.106 remote-as 13979
neighbor 10.168.88.106 allowas-in
neighbor 10.168.88.106 soft-reconfiguration inbound
02-22-2018 09:52 AM - edited 02-22-2018 10:17 AM
Please correct me if I understanding wrong the question, but It can work being the same address (except if 2 or more routers have the same router-id) , probably the router-id is a loopback IP and the BGP peering is being created with the loopback known through a NLRI like RIP, EIGRP, OSPF, ISIS, etc or static routing. Once the BGP process is created it will create an identifier with a valid IP, so you could select your own ID as well to avoid leave it randomly.
02-22-2018 10:17 AM
Hi Brandon,
IOS only checks that the router ID is a valid IP address, hence why it works for you.
