BGP routes are inaccessible for 60 seconds after BGP reset
When I do a BGP neighbor reset or a new BGP session goes to established, then the BGP routes are "inaccessible" for about 60 seconds.
This is how i looks shortly after the BGP session comes up:
BGP routing table entry for 1.2.3.4/32, version 0
BGP Bestpath: deterministic-med: med
Paths: (2 available, no best path)
  Not advertised to any peer
  Refresh Epoch 2
  15623
    10.0.0.1 (inaccessible) from 10.0.0.1 (1.1.1.1)
      Origin IGP, metric 0, localpref 100, weight 5000, valid, external
      rx pathid: 0, tx pathid: 0
  Refresh Epoch 2
  15623, (received-only)
      Origin IGP, metric 0, localpref 100, valid, external
This is how it looks after about 60 seconds:
BGP routing table entry for 1.2.3.4/32, version 3
Paths: (2 available, best #1, table default)
  Refresh Epoch 2
  15623
    10.0.0.1 from 10.0.0.1 (1.1.1.1)
      Origin IGP, metric 0, localpref 100, weight 5000, valid, external, best
      rx pathid: 0, tx pathid: 0x0
  Refresh Epoch 2
Because of that, the routes are installed 60 seconds after the BGP session goes to established. Can anyone explain me, what this 60 seconds timer is? Can I reduce the time, that the routes are installed faster in the routing table?
BGP usually has a slow convergence but it also depends of the amount of prefixes received. You could try using BFD. Also you can customize the timers but it could not be recommended. The 60 seg is the keepalive timer. The inaccessible term is displayed until the route has a valid next hop.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Hi Julio
It's a lab setup, the router learns less then 5 prefixes. The hold time is 15 seconds. I don't think, I can tune something here.
The BGP process learns the prefixes verf fast, but I wonder, that he set them to "inaccessible" for around 60 seconds.
If this is a feature from BGP, then it's ok. But if I can tune them, it would be great.
Try with
neighbor <neighbor IP> timers <keepalive holddown> <minimum holddown>
This is actually the BGP hold timer in action. When you reset the neighbor the routes are put in hold-down to prevent flapping and instability. By default the hold timer is four times the hello timer (4 x 15s = 60s in your lab example). This is normal and should not be tuned to be too rapid in a production network, otherwise you risk instability. The usual way around this is to set up soft reconfiguration. Then you can do a soft reset rather than a full reset.
Hope this helps.
Dave
