BGP table convergence very slow
Hi all,
i have some problem regarding BGP table convergence. There are two router (ASR1K and CRS-3) which have a direct interface and peering with loopback0 adresses.
The BGP Peering is established, and prefixes are transfered. However, from ASR1K to CRS-3 the convergence is very slow. The CRS-3 only learnes about 200 prefixes/s. The other direction CRS-3 to ASR1K works as apected, BGP full table is transfered within 30s. This is the output on ASR1K. MTU-Path-Discovery is enabled on both routers.
ASR1K#sh ip bgp neighbors x.x.x.x
BGP neighbor is x.x.x.x,  remote AS xxxx, internal link
Description: CRS-3
Inherits from template BGP-TEMPLATE for session parameters
  BGP version 4, remote router ID x.x.x.x
  BGP state = Established, up for 2d17h
  Last read 00:00:23, last write 00:00:02, hold time is 180, keepalive interval is 60 seconds
  Keepalives are temporarily in throttle due to closed TCP window
Does anybody have an idea about this?
Best Regards
Marco
Hello
Can you post your bgp configuration?
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
