BGP update-source command not working
MapleMagician
I have created the most simple scenario to try and understand the
update-source
command and yet I cannot seem to get these two devices to peer. Trying to peer loopback5 on R500 with g0/2 on R4. Everything is reachable via OSPF, I cannot make sense of why it isn't working.
R500 config
interface Loopback5
ip address 5.5.5.5 255.255.255.255
interface GigabitEthernet0/0
ip address 11.5.0.5 255.255.255.0
duplex auto
speed auto
media-type rj45
router ospf 1
network 0.0.0.0 255.255.255.255 area 0
router bgp 500
bgp log-neighbor-changes
neighbor 11.5.0.4 remote-as 200
neighbor 11.5.0.4 update-source Loopback5
Router 4 config
interface GigabitEthernet0/2
ip address 11.5.0.4 255.255.255.0
duplex auto
speed auto
media-type rj45
router ospf 1
router bgp 200
network 11.200.54.0 mask 255.255.255.0
network 11.200.144.0 mask 255.255.255.0
neighbor 5.5.5.5 remote-as 500
neighbor 11.200.54.5 remote-as 200
neighbor 11.200.144.14 remote-as 40
Add neighbor ebgp multihop
Since now it one hop far between two bgp peers
Or disable direct connect <- this I prefer in case we use LO as update source
MHM
MHM
Yes! Both of these methods worked without even needing the
update source
command. This just filled some big holes in my understanding of bgp peering. Thank you!
Friend you are so so welcome
MHM
