BGP update-source loopback 0 doesn't work
StefanStefanR
Hello, I have this network where D1, D2 and D3 routers are configured as iBGP.
Network works just fine until I do the command:
neighbor x.x.x.x update-source loopback 0
on each router.
Once this is done, routers begin to shutdown their neighbors after 180 seconds have passed, removing the topology table. This is the error that I'm getting:
D1;
router bgp 64530
bgp router-id 1.1.1.1
bgp log-neighbor-changes
network 1.2.3.4 mask 255.255.255.255
network 10.10.11.0 mask 255.255.255.252
network 10.10.12.0 mask 255.255.255.252
network 150.224.224.196 mask 255.255.255.252
network 180.200.200.0 mask 255.255.255.252
neighbor 10.10.11.2 remote-as 64530
neighbor 10.10.12.1 remote-as 64530
D2;
router bgp 64530
network 10.10.13.0 mask 255.255.255.252
network 10.10.100.0 mask 255.255.255.252
network 10.16.0.0 mask 255.240.0.0
network 180.110.100.100 mask 255.255.255.255
redistribute ospf 1 route-map OSPF_FILTER
neighbor 10.10.12.2 remote-as 64530
neighbor 10.10.13.1 remote-as 64530
D3;
router bgp 64530
network 10.10.14.0 mask 255.255.255.252
network 10.10.154.208 mask 255.255.255.240
network 10.10.189.0 mask 255.255.255.240
network 10.10.198.0 mask 255.255.255.0
network 180.100.100.100 mask 255.255.255.255
redistribute static
neighbor 10.10.11.1 remote-as 64530
neighbor 10.10.13.2 remote-as 64530
Router D2 has OSPF process but only with the router OfficeA-1 which is down next to him.
The issue persists once I start configuring the
update-source
command. Let's say I go to D2 and put:
neighbor 10.10.12.2 update-source loopback 0
neighbor 10.10.13.1 update-source loopback 0
and then I do the same for the rest of them. They will still maintain the bgp peering until hold timer ends and then they start shutting themselves down and routers also go to a full freeze mode with no respond, so I have to stop routers and force a restart of an IOS system.
Any clue to why this happens? Do I need to have IGP configured with iBGP maybe?
Hello @StefanStefanR ,
2) Doing the command:
show ip protocols
 on each router, shows that BGP sessions are connected via
Loopback 0
but then it also shows that their Gateways for neighbors are containing their
next-hop
addresses as well. Even though I disabled
neighbor
command for these and reset the bgp session. Here look at the image below;
D3 shows 1.2.3.4 which is okay
180.110.100.100
correct, but then it also shows his
10.10.13.2 and 10.10.11.1 neighbor's next-hop addresses of Gigabit0/0 - 0/1 interface
I assume this is the "correct" behavior or I have done something wrong?
My guess is that the
show ip
protocols is reporting also the old neighbors configured if you see the last update is more then one hour ago on the two addresses on LAN interfaces.
3)   Your understanding is correct iBGP AD is
200 > OSPF AD 110
so all routes advertised in OSPF are RIB failure in BGP. This is normal
You need an IGP to build iBGP sessions terminated on loopbacks this is the most important take away of your tests.
Hope to help
Giuseppe
6 Replies 6
You need to make sure that the D1-D3 routers Loopbacks are reachable from each other. If you only have OSPF configure on one router then I assume you don't have any routing protocol to help inform the routers about each others loopbacks.
When a BGP neighbor statement is configure with the
update-source
command then it sends BGP messages to its configured neighbor with that address. When the neighbor BGP router receives it it will see it needs to connect to the
update source
IP (which in your case is the Lo0). It will look into its routing table and if you don't have routing/static route configured then it wont establish an adjacency. Before you enter the neighbor command
update-source
the router will use the exit interface as the
update-source
This is reachable by the neighbor since they ar eon the same link and in the same network, therefor it does not need any additional neighbor statements to connect.
Once you include the
update-source
command the router will time out in the 3 minutes as you have mentioned because it has not way to route to the Loopback you specified in the BGP message.
You can configure static routes, OSPF, EIGRP, etc between routers and advertise the
Loopback 0
into them to provide the reachability you need.
-David
Harold Ritter
Hi @StefanStefanR ,
In addition to what @David Ruess mentioned about making sure the lo0 IP address is propagated via the IGP, the
update-source
would normally be used if you use the loopback interface IP addresses to peer.
I notice that you are rather using the physical interfaces to peer
(10.10.11.1, 10.10.11.2, 10.10.12.1, 10.10.12.2, 10.10.13.1, 10.10.13.2)
which is counterintuitive and will lead to unexpected results.
You should definitely use the loopback interface IP address of each router
(1.2.3.4/32, 180.110.100.100/32 and 180.100.100.100/32)
in the neighbor statement if you are going to use
update-source lo0
StefanStefanR
@David Ruess @Harold Ritter
Thank you very much for your detailed explanation. Here is the current image so you get the idea of what is happening.
On routers D1, D2 and D3, I removed all
neighbor
commands. Then I added the
neighbor
commands again but this time not using their physical interfaces but loopbacks.
For an example:
D1(config-router)#neighbor 180.110.100.100 remote-as 64530
D1(config-router)#neighbor 180.110.100.100 update-source loopback 0
I did this for each one of them. BGP sessions are not established since as you mentioned, an IGP is needed to advertise these routes. D2 and OfficeA-1 are working with
OSPF process 100
and they are in
AREA 1
(for making OfficeA-1 as a stub router). Afterwards, I made on D2 another
OSPF process 1
but here he is using
AREA 0
(the backbone).
I advertised the networks on D2 like this:
network 10.10.0.0 0.0.255.255 area 0
network 180.110.100.100 0.0.0.0 area 0
I am using
network because it will catch all his directly connected links and I don't have the need to type every single one of them (at least I think so).
I did these commands on all other routers D1 and D3. All
area 0
backbone. After I advertised these networks via OSPF, all routers have made OSPF process 1 adjacency with each other. Afterwards, BGP sessions have been established as well. Everything is going fine right now.
Then on D2 router I redistributed OSPF 100 process routes into BGP (I was in a dilemma if I should redistribute this into
ospf 1 or bgp 64530
but I went with bgp anyways). With command:
redistribute ospf 100 route-map OSPF_FILTER
. This filter just makes sure that only
192.168.100.0
and
192.168.150.0 (Vlan 100 / 150)
are advertised into bpg and not
.99.0 (Vlan 99)
network.
I did the pings from PC's, routers and whole network is connected successfully.
But, I still need some deep throughout explanation on a few things that have been occurring here.
1) Why are routers D1 and D3 connected with D2 via
10.16.0.1
Loopback 1 network for OSPF? Why not pick Loopback 0?
Nevermind, I actually figured this question out. The issue is that OSPF process 100 is already using Loopback 0 as his router-ID. But OSPF process 1 is using Loopback 1 router-id because Loopback 0 is already used for another process. My bad, I'm sorry. I understand this question now. I actually checked show ip protocols and it shows right there.
show ip protocols
on each router, shows that BGP sessions are connected via Loopback 0 but then it also shows that their Gateways for neighbors are containing their
next-hop
neighbor
D3 shows 1.2.3.4 which is okay,
180.110.100.100
addresses of
Gigabit0/0 - 0/1
interface. I assume this is the "correct" behavior or I have done something wrong?
3) When I do
show ip bgp
, let's say on D3. He implies that some routes have
rib-failures
(which is fine since they are using OSPF). Message is "Higher administrative distance''. All 3 routers are experiencing this.
I assumed that because of OSPF, it should state "Lower administrative distance" failure but not higher. I'm wondering if I should just do
bgp suppress-inactive
command or this would make a mess in the network when other routers are configured?
Here below are configurations of D1, D2, D3;
D1:
router ospf 1
network 1.2.3.4 0.0.0.0 area 0
router bgp 64530
neighbor 180.100.100.100 remote-as 64530
neighbor 180.100.100.100 update-source Loopback0
neighbor 180.110.100.100 update-source Loopback0
D2:
router ospf 100
network 10.10.100.0 0.0.0.3 area 1
router ospf 1
router bgp 64530
neighbor 1.2.3.4 remote-as 64530
neighbor 1.2.3.4 update-source Loopback0
D3:
router ospf 1
network 180.100.100.100 0.0.0.0 area 0
router bgp 64530
redistribute static
What are the static routes o D3? You have those being redistributed into BGP as well.
There's only one single static route of
10.255.255.0
from D3. That one is redistributed yes. That route goes up to the
10.10.14.0
network because there is a router there. D3 uses a static route to reach his LAN network. Router on that other side is using a simple default route of
0.0.0.0
to communicate with the rest of the network. There's no issue there only that route has "?" mark next to it but that's because it's redistributed.
I mean, everything is working fine right now. I managed to fix the whole network thanks to your help. I only have those two questions about BGP behavior.
The command
show ip protocols
states that neighbors are loopbacks 0 but it also contains the physical addresses of the directly connected interface. I can only assume that this is the correct behavior because it is an intriguing find. Maybe this is just how it works?
As for BGP showing
rib-failures
that one is totally acceptable. Those are bound to happen no matter what. I was only double minded if it should say: ''Higher admin distance'' or "Lower admin distance''. But to my surprise, "Lower admin distance" message doesn't even exist (at least from searching over the internet), so my guess is that ''Higher admin distance'' is the correct thing to pop-up.
Why I think that this is correct? Because
180.110.100.100, 10.10.12.0 and 1.2.3.4 on D3 show rib-failure
as those routes are also learned via OSPF process. So normally even though BGP is also advertising them, D3 prefers the OSPF ones. This behavior happens on all routers which is acceptable and I think there's no way to fix this.
Doing the
bgp supress-inactive
might not be the case here since there are no different next-hops.
As I stated, the network is fine right now. I only had these two questions brought up because they are interesting ones, at least for me.
show ip protocols
Loopback 0
next-hop
neighbor
180.110.100.100
show ip
200 > OSPF AD 110
Hope to help
Giuseppe
