BGP Updates Question
haithamnofal
Level 3
Level 3
I configured iBGP on 2 routers in my lab and a PIX in between them. I allowed TCP traffic between the 2 in the PIX.
I could see out of the debug output a successfull BGP communication as follows:
*Mar 1 03:44:24.755: BGP: Import walker start version 0, end version 1
*Mar 1 03:44:24.755: BGP: ... start import cfg version = 0
Router(config-router)#
*Mar 1 03:44:45.755: BGP: 2.2.2.2 went from Idle to Active
*Mar 1 03:44:45.755: BGP: 2.2.2.2 open active, delay 9004ms
*Mar 1 03:44:54.759: BGP: 2.2.2.2 open active, local address 1.1.1.1
*Mar 1 03:44:54.763: BGP: 2.2.2.2 went from Active to OpenSent
*Mar 1 03:44:54.763: BGP: 2.2.2.2 sending OPEN, version 4, my as: 1
*Mar 1 03:44:54.763: BGP: 2.2.2.2 send message type 1, length (incl. header) 45
*Mar 1 03:44:54.771: BGP: 2.2.2.2 rcv message type 1, length (excl. header) 26
*Mar 1 03:44:54.771: BGP: 2.2.2.2 rcv OPEN, version 4
*Mar 1 03:44:54.771: BGP: 2.2.2.2 rcv OPEN w/ OPTION parameter len: 16
*Mar 1 03:44:54.771: BGP: 2.2.2.2 rcvd OPEN w/ optional parameter type 2 (Capab
ility) len 6
*Mar 1 03:44:54.775: BGP: 2.2.2.2 OPEN has CAPABILITY code: 1, length 4
*Mar 1 03:44:54.775: BGP: 2.2.2.2 OPEN has MP_EXT CAP for afi/safi: 1/1
*Mar 1 03:44:54.775: BGP: 2.2.2.2 rcvd OPEN w/ optional parameter type 2 (Capab
ility) len 2
*Mar 1 03:44:54.775: BGP: 2.2.2.2 OPEN has CAPABILITY code: 128, length 0
*Mar 1 03:44:54.775: BGP: 2.2.2.2 OPEN has ROUTE-REFRESH capability(old) for al
l address-families
ility) len 2
*Mar 1 03:44:54.775: BGP: 2.2.2.2 OPEN has CAPABILITY code: 2, length 0
*Mar 1 03:44:54.775: BGP: 2.2.2.2 OPEN has ROUTE-REFRESH capability(new) for al
l address-families
*Mar 1 03:44:54.775: BGP: 2.2.2.2 went from OpenSent to OpenConfirm
*Mar 1 03:44:54.779: BGP: 2.2.2.2 went from OpenConfirm to Established
*Mar 1 03:44:54.779: %BGP-5-ADJCHANGE: neighbor 2.2.2.2 Up
*Mar 1 03:44:55.083: BGP(0): 2.2.2.2 computing updates, afi 0, neighbor version
0, table version 1, starting at 0.0.0.0
*Mar 1 03:44:55.083: BGP(0): 2.2.2.2 update run completed, afi 0, ran for 0ms,
neighbor version 0, start version 1, throttled to 1
*Mar 1 03:44:55.083: BGP(0): 2.2.2.2 initial update completed
*Mar 1 03:45:09.759: BGP: Import walker start version 0, end version 1
*Mar 1 03:45:09.759: BGP: ... start import cfg version = 0
However, when I do show ip route on any of the 2 routers I dont see the network updates of the networks which are added to the BGP router config. (i.e. when I do "show ip route" I dont see BGP updates in there!!
I tried to connect the routers directly with no PIX and the same happens.
Here is my BGP config on R1:
router bgp 1
no synchronization
bgp log-neighbor-changes
network 1.1.1.0
network 7.7.7.0
network 10.10.10.0
neighbor 2.2.2.2 remote-as 1
neighbor 2.2.2.2 update-source Loopback0
no auto-summary
on R2:
router bgp 1
no synchronization
network 2.2.2.0
network 4.4.4.0
network 10.10.20.0
neighbor 1.1.1.1 remote-as 1
neighbor 1.1.1.1 update-source Loopback0
no auto-summary
What is also surprising is that when I run "sho bgp" on any of the 2 routers, I dont see any output!!
Any idea on why the routing table is not getting propogated?
My other question is how frquent BGP updates happens? I tried to disable the loopback interfaces but I couldnt see any BGP down messages on any of the 2 routers!!
I wish you can help me here.
Haitham
2 Accepted Solutions
Haitham,
For BGP to advertise a network via the network command, there must be an exact match of this network in the routing table, moreover if the network command under the BGP is configured without a mask, then it will use the default classful mask, and thus in your case it didn't find an exact match in the routing table, since 2.2.2.2 belongs to the Class A, while you are using it with a /24, thus all you need to solve your issue, is use "network 2.2.2.0 mask 255.255.255.0".
interface Loopback0
ip address 2.2.2.2 255.255.255.0
BR,
Mohammed Mahmoud.
Haitham,
You are very welcomed, "neighbor x.x.x.x ebgp-multihop x" command is required whenever an ebgp session is configured with any other interface other than the directly connected, which applies to your case. But the reason behind the error you see is that your router is using a default route to reach its peer address, a default route is never going to be used to establish a BGP session (iBGP or eBGP) this is the reason for "no route" in the output of the debugs, although you will be able to ping the BGP neighbor, you need a more specific route rather than the default route.
BR,
Mohammed Mahmoud.
6 Replies 6
mohammedmahmoud
Level 11
Level 11
Hi Haitham,
Can you please post, show ip bgp summary, show ip bgp and show ip route from both routers.
BR,
Mohammed Mahmoud.
guruprasadr
Level 7
Level 7
HI Haitham, [Pls Rate if HELPS]
Your Configuration looks OK
Can you paste the "sh ip bgp summary" output and see whether the BGP status as "Active" or NOT
Execute "ip route 1.1.1.1" and viceversa on other Router to see from where its learning.
Also for a BGP to Origniate a Route it needs a "Route" to be available in the Global Routing Table. Add a static route for the Adversised prefixes pointing to the NULL0 Interface.
By default, the keepalive timer is 60 seconds, and the holdtime timer is 180 seconds.
Also try to execute the commands at both sides of Router to see the Results:
router bgp 1
neighbor 1.1.1.1 shutdown
no neighbor 1.1.1.1 shutdown
"Viceversa on other Router"
Refer the document about Configuring BGP:
http://www.cisco.com/en/US/docs/ios/11_3/np1/configuration/guide/1cbgp.html
Pls Rate if HELPS
Best Regards,
Guru Prasad R
Hi Guru and Mohammed,
The "show ip bgp" shows nothing.
The "show ip bgp summary" is as follows:
on R1:
R1#sho ip bgp summary
BGP router identifier 7.7.7.1, local AS number 1
BGP table version is 1, main routing table version 1
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
2.2.2.2 4 1 68 68 1 0 0 01:04:12 0
192.1.24.4 4 13 0 0 0 0 0 never Active
R1#sho ip b
1.1.1.1 4 1 152 168 1 0 0 01:03:52 0
on R2:
R2#sho ip bgp summary
BGP router identifier 10.10.20.1, local AS number 1
The particular R1/R2 relationship is not Active as you can see here!!
Here is R1 complete config:
Current configuration : 1480 bytes
version 12.2
hostname R1
interface Loopback0
ip address 1.1.1.1 255.255.255.0
interface Loopback30
ip address 7.7.7.1 255.255.255.0
interface Ethernet0/0
ip address 10.10.10.1 255.255.255.0
half-duplex
router bgp 1
no synchronization
network 1.1.1.0
network 7.7.7.0
network 10.10.10.0
--More--
neighbor 192.1.24.4 remote-as 13
neighbor 192.1.24.4 ebgp-multihop 255
no auto-summary
ip route 0.0.0.0 0.0.0.0 10.10.10.253
ip route 1.1.1.1 255.255.255.255 10.10.20.254
ip route 2.2.2.2 255.255.255.255 10.10.10.254
R2 config:
Building configuration...
Current configuration : 1256 bytes
version 12.2
hostname R2
interface Loopback0
interface Loopback10
ip address 4.4.4.1 255.255.255.0
ip address 10.10.10.254 255.255.255.0
half-duplex
router bgp 1
no synchronization
network 2.2.2.0
network 4.4.4.0
network 10.10.20.0
no auto-summary
--More--
ip http server
no ip http secure-server
ip classless
ip route 1.1.1.1 255.255.255.255 10.10.10.1
call rsvp-sync
mgcp profile default
dial-peer cor custom
call rsvp-sync
line con 0
line aux 0
line vty 0 4
end
R/ Haitham
Haitham,
interface Loopback0
BR,
Mohammed Mahmoud.
Thanks Mohammed, this is really appreciated the iBGP worked perfectly.
I have another question if you allow me, during the same lab setup, I am configuring eBGP to a 3rd router connected thru a core switch. Do I need to configure the command "neighbour x.x.x.x ebgp-multihop"?
I am getting this error message when running debug:
*Mar 1 05:33:20.062: BGP: 192.1.24.4 multihop open delayed 14902ms (no route)
The BGP is between R1 which I sent its config before and R4. Both are able to ping the loopback interfaces of each other and here is R4 config:
Current configuration : 1306 bytes
version 12.2
hostname R4
logging queue-limit 100
memory-size iomem 10
ip subnet-zero
ip audit notify log
ip audit po max-events 100
mpls ldp logging neighbor-changes
--More--
interface Loopback0
ip address 9.9.9.9 255.255.255.0
interface Ethernet1/0
ip address 192.1.24.4 255.255.255.0
half-duplex
interface ATM2/0
no ip address
shutdown
no atm ilmi-keepalive
router bgp 13
no synchronization
network 9.9.9.0 mask 255.255.255.0
network 192.1.24.0
neighbor 10.10.10.1 remote-as 1
neighbor 10.10.10.1 ebgp-multihop 255
neighbor 10.10.10.1 update-source Loopback0
no auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 192.1.24.254
The sho ip bgp summary from R4 is:
R4#sho ip bgp summary
BGP router identifier 192.1.24.4, local AS number 13
BGP table version is 3, main routing table version 3
2 network entries using 202 bytes of memory
2 path entries using 96 bytes of memory
1 BGP path attribute entries using 60 bytes of memory
0 BGP route-map cache entries using 0 bytes of memory
0 BGP filter-list cache entries using 0 bytes of memory
BGP using 358 total bytes of memory
BGP activity 2/0 prefixes, 2/0 paths, scan interval 60 secs
10.10.10.1 4 1 0 0 0 0 0 never Active
In case I did some changes, here is the R1 BGP cinfig:
router bgp 1
no synchronization
network 1.1.1.0 mask 255.255.255.0
network 7.7.7.0 mask 255.255.255.0
network 10.10.10.0
neighbor 192.1.24.4 update-source Loopback0
no auto-summary
and here is the show ip bgp summary from R1:
BGP table version is 5, main routing table version 5
4 network entries using 404 bytes of memory
4 path entries using 192 bytes of memory
2 BGP path attribute entries using 120 bytes of memory
BGP using 716 total bytes of memory
BGP activity 4/0 prefixes, 4/0 paths, scan interval 60 secs
2.2.2.2 4 1 118 118 5 0 0 01:52:53 2
R1#
Haitham,
BR,
Mohammed Mahmoud.
