BGP with 2 ISPs?
tinhnho123
Level 2
Level 2
Hi Everyone,
I currently have a router that works with 4G LTE and it's been up for few months. I also have an WAN connection which from different ISP, I'd like to create internet redudancy for this router. I did a research and found that we can do it with BGP, I haven't tried it before can someone please shed me some lights if you have done it before? Thanks.
Please note: Both internet conenctions don't have static public IP addresses.
Simon Brooks
Are you peering using bgp. Sounds like not to me. If you just want redundancy then lookup floating static routes.
Sent from Cisco Technical Support Android App
paolo bevilacqua
Thais is often asked, had you searched before asking.
You cannot do BGP with your ISPs.
You can only do the following:
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a0080950834.shtml
