BGP with two ISP
amaresh_22jan
HI All,
Please find the scenario below
Two router (Router A and Router B) with one ISP link terminated on each router . EBGP is established with the ISP router and IBGP between Router A and Router B
As of now all outgoing trafffic orginated from local network goes via Link A (terminated on router A)
Wheres as incoming traffic comes via Link B (terminated on router B) resulting in assymetric .
Now for specific destination host say 1.1.1.2 we want to send the traffic via link B . I belive we need to configure AS path attribute.
Kindly help me with configuration for particular destination host.
7 Replies 7
do both routers connect to the same ISP AS, or different IPS ASs ?
Different ISP AS
you can use local preference. The below would need to be configured on the router connected to ISP B. In this sample config, iBGP AS is 1, and the eBGP AS is 3:
router bgp 1
bgp router-id 2.2.2.2
bgp log-neighbor-changes
network 2.2.2.2 mask 255.255.255.255
neighbor 192.168.12.1 remote-as 1
neighbor 192.168.12.1 next-hop-self
neighbor 192.168.24.4 remote-as 3
neighbor 192.168.24.4 route-map LOCPREF in
ip prefix-list LOCAL seq 5 permit 1.1.1.2/32
route-map LOCPREF permit 10
match ip address prefix-list LOCAL
set local-preference 200
route-map LOCPREF permit 20
set local-preference 150
Thanks for the response.
Below is the current config on the secondary router
router bgp 45XXX
bgp dampening
network 202.19.138.0
neighbor 124.17.58.89 remote-as 94XX
neighbor 192.168.10.1 remote-as 45XXX
neighbor 192.168.10.1 next-hop-self
202.19.138.0 is the network advertise on both the router
124.17.58.89 is the neighbor peer ip of the ISP
192.168.10.1 is used for IBGP between the router
Hello
Local Preference and AS-prepending would be a viable option but I would also suggest to apply some filtering on your bgp rtrs so to negate the possibility of your rtrs becoming a transit path for either ISP
The below example should allow RTRB be the preferred rtr to reach outbound towards 1.1.1.0/24
and all ingress traffic to come in via RTRA
Lastly the filter-list only allows local subnets to be advertised to either ISP and not any EBGP prefixes.
RTR-A
ip as-path access-list 10 permit ^$
route-map LP-ISP1 permit 10
set local-preference 40000
router bgp 45XXX
neighbor (ISP1) route-map LP-ISP1 in
neighbor (ISP1) filter-list 10 out
RTR-B
access-list 10 permit 1.1.1.0 0.0.0.255
route-map LP_ISP2 permit 10
match ip  address 10
set local-preference 50000
route-map LP_ISP2 permit 99
set local-preference 10000
route-map RTRB-AS-prepend permit 10
set as-path prepend 45XXX 45XXX 45XXX
router bgp 45XXX
neighbor (ISP2) route-map LP-ISP2 in
neighbor (ISP2)filter-list 10 out
neighbor (ISP2) route-map RTRB-AS-prepend out
res
Paul
Kind Regards
Paul
Thanks everyone.
By  default all the traffic is originating from Router A  but some return traffic is coming back  by Router B.
Now we want traffic 1.1.1.2 should come back by router A (link A)  only. Does the below config will suffice the requirement.  Where as other return traffic may return via router A or  Router B
On Router B
router bgp 45XXX
bgp dampening
neighbor (ISP2)  remote-as 94XX
neighbor (ISP2) route-map ASPATH  out
ip prefix-list AS  seq 5 permit 1.1.1.2/32
route-map ASPATH permit 10
Rick Morris
Level 6
Level 6
There are a couple of ways to do what you want.
If you want to do some load sharing you can subnet your network, assuming you can do so based on block size, then announce each out their separate links.
For instance:
8.8.8.0/23
Subnet
8.8.8.0/24
8.8.9.0/24
Router A
Local pref for 8.8.8.0/24
prepend AS for 8.8.9.0/24
Router B
Local pref for 8.8.9.0/24
prepend AS for 8.8.8.0/24
What you get is a way to break up the block, use both links AND have failover to each other in the event of a carrier issue taking one link down over the other.
IF you are using one as a primary and one as a backup:
Router A
local pref for 8.8.8.0/23
Router B
prepend AS for 8.8.8.0/23
This way you are telling the upstream providers to use one connection over the other by your AS prepending for incoming traffic. Outbound is controlled by local pref
