07-04-2005 06:39 AM - edited 03-03-2019 09:57 AM
Hi.
I have a problem where the best path to a particular destination is being withdrawn by BGP.
To explain.
Site A has 2 links to site B. 1 via an eBGP peer over MPLS, 2 via an iBGP peer over a VPN backup.
I have configured the ebgp peer with a higher weight so that it is preferred.
The problem is this.
When the link to the ebgp peer goes down, the link via the ibgp peer is preferred.
When the link via the ebgp peer comes back up, the route via the ebgp peer does not go back into the BGP table (in fact it goes back for a second and is then withdrawn).
Could someone help me on this one.
Lee
Solved! Go to Solution.
07-04-2005 03:13 PM
It would go something like this:
RtrA:
router bgp 65500
neighbor MPLS route-map setMed out
route-map setMed permit 10
match ip address 1
set med 2
route-map setMed permit 20
set med 1
access-list 1 permit
RtrC:
router bgp 65500
match ip address 1
set med 2
set med 1
Let me know if you have any issues,
07-04-2005 09:26 AM
Can you tell us more about the topology of site A and B. Is the iBGP and eBGP session from the same two CEs? A sample topo would be nice.
07-04-2005 09:41 AM
thanks for the reply, I have attached a diagram of the topology and the BGP configs of all 3 routers is below.
One other thing, the only way I can get the preffered route to appear back in the BGP table once the MPLS link is back is to do a hard reset of the peer connected via the backup link
Thanks in advance
Lee
RTR A Config
router bgp 65500
no synchronization
bgp log-neighbor-changes
bgp redistribute-internal
network 10.3.64.0 mask 255.255.224.0
redistribute connected metric 10
redistribute static metric 10
redistribute ospf 10 metric 10 match internal external 1 external 2
neighbor RTR B remote-as 65500
neighbor RTR B next-hop-self
neighbor RTR B route-map NEXTHOP in
neighbor MPLS remote-as 65000
neighbor MPLS soft-reconfiguration inbound
neighbor MPLS weight 200
no auto-summary
RTR B Config
router bgp 65500
no synchronization
neighbor VPN_BACKUP_MESH peer-group
neighbor VPN_BACKUP_MESH remote-as 65500
neighbor VPN_BACKUP_MESH route-reflector-client
neighbor RTR C peer-group VPN_BACKUP_MESH
neighbor RTR A peer-group VPN_BACKUP_MESH
neighbor 10.3.77.33 weight 200
no auto-summary
RTR C Config
router bgp 65500
no synchronization
network 10.1.144.0 mask 255.255.240.0
neighbor RTR B soft-reconfiguration inbound
neighbor RTR B prefix-list SYDNEY_ROUTES out
no auto-summary
07-04-2005 11:07 AM
The issue is that the PE router prefers the route received via the CE (iBGP) rather than the one received via the other PE (iBGP).
On the site A CE, try setting the MED for site B routes sent to the MPLS cloud to 2 and 1 for local routes. The same should also be done on the site B CE. This will ensure that when the eBGP session comes back up, the PEs will prefer the route from the directly connected PE.
Hope this helps,
07-04-2005 01:25 PM
Hi hritter
Thanks again for your help. I have tried to do what you suggested however I am not quite sure I understand what you are asking me to do.
Is there any chance you coudl find the time to write down the config changes I would need to make on each of my routers ?
Lee
07-04-2005 03:13 PM
RtrA:
router bgp 65500
match ip address 1
set med 2
set med 1
RtrC:
router bgp 65500
match ip address 1
set med 2
set med 1
07-05-2005 05:07 AM
Hritter,
That works perfectly, thanks very much for your help.
Lee
