BGP
ccie_rooky
When I run sh run on the router, I don't any information about BGP at all in the output. However, when I run sh IP bgp..., I can see the IBGP and EBGP information. I have security level of 15. Any reason why the 'show running config" does not include BGP info?
5 Replies 5
Tharak Abraham
Level 3
Level 3
Is that only for BGP config or is it the same for IGP too ?
try "sh run | section bgp" or "sh run | begin bgp" or "sh run | in router bgp" et al...just curious..-:)
It is for both IBGP and EBGP. Nothing shows at all.
run the below command , you will get all the BGP config info
#sh run | b r bgp
Karuppu
Thanks for your help. But why
the BGP info doesn't show up if I don't use the output modifier?
Thanks.
You may want to look at updating the IOS. I seem to remember someone else on here having the same issue until they updated. What type of equipment are you running and IOS version?
John
HTH, John *** Please rate all useful posts ***
