12-23-2021 02:18 AM
I am configuring ebgp, one side i have AS 100 and another side I have AS 200, when I am unable to make them neighbor
what can be the reason.
Ashok
12-23-2021 03:27 AM
is the neighbor is direct connect or you use loopback ? if you use loopback then check the reachability and if it reachable it may need to enter ebgp multi hop command.
12-23-2021 03:45 AM
There are thousand reasons. Be more specific and you can be helped. First step is reachiability as mentioned in the other answer. But does not stop there.
BGP is a layer 4 connection between nodes on TCP port 179. It does not required direct connection but if you are a few hops away you may need ajust ebgp multi hop as mentioned.
Start with that and post your progress. You can also share the command "show run | sec router bgp" in order to speed up things.
12-23-2021 04:26 AM
I have direct connected nodes but in different AS, and not using any loopback address there
12-23-2021 03:50 AM
post the running configs of both routers.
12-23-2021 04:29 AM
Hello
Do you have ip connectivity between the rtrs?
if your peering on loopbacks then do the rtrs have knowledge how to reach those loopbacks and at least on side needs to peer with neighbour xxx update- source loopback x and disable-check-connected or ebgp-multihop
Do NOT use default routes to try and establish peering use either static or dynamic igp routing for reachability
12-23-2021 10:07 AM
As mentioned by others we need more information to be able to understand the issues and to give good advice. It would be nice to see the complete current running config of both. But if you do not want to post complete configs it would help if you post the interface configs and the bgp config.
12-23-2021 10:14 AM
12-23-2021 10:24 AM
Ashok
Thanks for the update. Glad that you have been able to find the problem and solve it. Thanks for sharing this with the community.
