BGP
Hi!
I have a Cisco 2610XM router with Advanced Security IOS (c2600-advsecurityk9-mz.124-3.bin).
I have tried to use a BGP protocol but I couldn´t.
The BGP protocol is not available in this IOS image?
Thanks.
6 Replies 6
thisisshanky
Level 11
Level 11
So what happens when you type,
conf t
router bgp 100
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Sankar
When I try this in a router with the advanced security image I get an error stating protocol not in this image. Some of the feature sets do not include support for BGP.
Rick
Rick
Rick, you are right. Its not supported until, SP Services feature set.(and up). Check my previous post for the link which shows abt BGP support on various feature sets.
Sankar Nair
Thisisshanky,
I have typed again the command above and I received a message "protocol is not supported".
I accessed the link that you have suggested and the BGP is not available in this IOS image. I need to use another IOS version.
Thank you for your reply.
Rodnei
frenzeus
Level 4
Level 4
Hi. I don't think advanced security feature set includes bgp. I double checked with the feature navigator, bgp is not supported.
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Use the feature navigator to find out the appropriate image needed to support it. My guess is try something along the lines with enterprise feature set.
Rodney,
Look at this link.
http://www.cisco.com/en/US/products/ps5853/prod_bulletin0900aecd802edc81.html
Looks like only SP Services and up will support BGP.
Sankar Nair
