BGP
franklinmark
Is BGP not included in all IOS images I just bought a new 2811 router and it says bgp is not in this image.
6 Replies 6
mohammedmahmoud
Level 11
Level 11
BGP is supported starting from SP (Service Provider) feature set image.
Please see attached pic.
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
So I have to purchase the BGP module?
When I try to type
Router BGP
I get an error message stating that the protocol is not included in this image
This means that your image is most probably an IP Base image, you'll need to download at least a SP image.
Mohammed Mahmoud.
You can download it from Cisco website if you have a valid account:
Use Cisco IOS Feature Navigator:
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Mohammed Mahmoud.
Though Mohammed is right that all SP eservices image would support BGP, this is not the only feature set you would be looking for to run BGP.
The advance IP services and Enterprise service feature set also support BGP.
The advance security feature set did not support BGP but beginning with 12.4(4)T BGP support was added to this feature set..
Use the feature-navigator to see the features supported by your IOS
HTH, rate if it does
Narayan
