Bin files for Cisco 7940/7945 phones
morcomben
Hey team,
so I’m pretty new and I just built a home lab, 2x 2811, 2x 2960, 2x 3560, 2x 1841, and an ASA 5505.  The issue on having is the Voip phones fully configuring.  The phones will boot and it will pull the right default gateway and it will show an IP from the DHCP pool on the phone, but it would just constantly say configuring IP. Someone told me that I need bin files for the phone to finish registering. I’m just not sure if those files are even supported anymore or where to even get them any help would be much appreciated.
Depending on the IOS version on your router, it should be something like cme-124-24T.zip.
6 Replies 6
Leo Laohoo
What phone system are you planning to use, Cisco UCM or third-party?
I was tracking that Call manager express works on a 2811.  I’m just trying to do internal calling at the moment
If you download the full CME install file, that normally has the phone firmware images for the supported phones. That may be a little challenging for a 2811 since it is end of support.
That is the issue I have been running into since I went with a lower initial cost for my home lab.  I found a internet archive site that has iOS files, do you know what a CME install file naming architecture would look like by chance?
I’ll try that thanks sir
