Bind IP with MAC
tarun.shee
Respected Sir,
I want to bind IP with MAC Address in cisco router, that client can't change their IP Address from the same MAC Address.
Plz.Help.
Tarun
paolo bevilacqua
Hi, you had asked this question already, the answer is the same, disable dynamic arp under interface, and configure static arp entries in global config.
Sir,
according to your instruction, I have configrue. But not getting result. Configuration as follows-
interface GigabitEthernet2/0/4
description "Link To 55222"
switchport access vlan 7
switchport mode access
duplex half
speed 10
no arp arpa
arp 10.230.8.10 0017.5982.b010 ARPA
Tarun
This config goes on the router. It will not work on a switch unless it is a L3 switch and you enable routing.
sir,
This is Cisco 3750 switch. Am I need to changed the configuration.
Tarun
