06-08-2013 04:59 PM - edited 03-04-2019 08:08 PM
5505 - 9.02
I would like to disallow a range of IP's from getting through my firewall and attempting to authenticate. I've got the basic command -
access-list outside_in deny ip X.X.X.X 255.255.255.224 any
But does this command cause my ASA to respond with 'denied' or does it just ignore the traffic? I would rather it just ignore. Also, can the IP range be entered as a slash instead of subnet (i.e. /24 instead of 255.255.255.0)?
Solved! Go to Solution.
06-08-2013 09:47 PM
It just drops the traffic silently.
You can also prove this for yourself by downloading Nmap and getting it to port scan the IP(s) you're trying to protect.
06-08-2013 09:47 PM
06-15-2013 03:08 PM
Thanks!
Do you know if you can enter CIDR's for ACL's with a slash instead of listing the whole subnet?
