boot problem
minimintu
i am trying to configure the 2811 router but every time the router boots from rommon mode.how to make the router boot from normal mode????
help me out
15 Replies 15
pkhatri
Level 11
Level 11
When you boot up in rommon mode, are you then able to use the 'boot' command to boot up properly ?
If so, once you get back to the normal operating mode, enter the command 'config-reg 0x2102' and then save the config. The next time, the router should boot up properly.
If, however, you cannot get out of rommon at all, you may have a corrupt or missing image. You need to follow this procedure to perform recovery:
http://www.cisco.com/en/US/products/ps5854/prod_configuration_guide09186a00802c35e9.html#wp1070700
Hope that helps - pls do remember to rate posts that help.
Paresh
i have tried to configure according to the link provided by you.i am configuring through tftp.but the problem is that when i set these commands
ip_address=
ip_subnet_mask=
default_gateway=
tftp_server=
tftp_file=
set
tftpdnld
router gives error and it shows that IP address missing.i even changed the register as 0x2102 but the same error is coming. is the flash card got corrupted to such a level that it cannot be rectified??
help me out
Would it be possible for you to advise the exact values you are using when setting the above variables ?
And can you confirm that you have a PC running a TFTP server connected to your Ethernet port ?
Paresh.
IP_ADDRESS=172.16.23.32
IP_SUBNET_MASK=255.255.255.224
DEFAULT_GATEWAY=172.16.23.40
TFTP_SERVER=172.16.23.33
TFTP_FILE=tftp-root/c2801-i-mz
FE_PORT=0
tftp server is running on my PC. 2811 router has external flash card
I believe that part of the problem is the addressing that you are using. With the mask of 255.255.255.224 the address 172.16.23.32 is a subnet address not a host address. I suggest that you try changing the address used to 172.16.23.34.
Try that and let us know if it works better.
Rick
Rick
i have changed the IP address as 172.16.23.34 but still i am getting the same error
help me out
It is strange that it would still report the IP address as missing. Perhaps you could post the new settings of the variables as you did before and post a screen capture of the attempt to tftpdnld and the response message. This might help us find a solution.
Rick
Rick
csco10837896
Try to do it as following way:
IP_ADDRESS=172.16.23.1
IP_SUBNET_MASK=255.255.255.0
TFTP_SERVER=172.16.23.40
FE_PORT=0
tftpdnld
Make conectivity from router to machine via cross cable. copy ios in tftp root folder or C:\ tftp folder,run tftp from same folder.
TFTP_FILE=tftp-root/c2801-i-mz wrong just specify
c2801-i-mz with Extention as .t13 or .bin
I am sending you tftp server file
i have done the same configuration but still i am getting the same result.
i have attached the screen shot of the error
Hello Minimintu,
I saw all messeges in ur case in netpro,
Can u give me detail about ur flash card and IOS version and size so we can rectifiy the prob,
Chirag Pandya
IOS version is Cisco IOS Software, 2800 Software (C2800NM-IPBASE-M), Version 12.3(8)T8
Flash is c2800nm-ipbase-mz.123-8.T8.bin and size is
13273916
help me outttt
Thanks for posting the screen shots. Unfortunately both screen shots show the error, but do not show how the variables have been set. The error indicates that something is a problem about the setting of IP_ADDRESS and it would be helpful if we could see exactly how it (and the other variables) are set. Can you post a screen shot which shows how all the variables are set?
Rick
Rick
csco10837896
TFTP_FILE=c2800nm-ipbase-mz.123-8.T8.bin
FE_PORT=0
tftpdnld
or i think .t8 is your extention of file
if yes then try
c2800nm-ipbase-mz.123-8.T8 only
Pls rate this post,
Yogesh
i have done the configuration as above but i am getting the same error.
Is the flash destroyed permantely???
