BOOT router image
sifathmirza
Hi All,
   in my cisco 2800router i have 64mb compactflash and i want to upload 53mb ios i don't have enough free space then i removed
old image and upload new ios & gave boot system command,  then it should load with new IOS image. but after reloading its gone to ROMMON mode iam not able to boot the image from rommon mode ,, is their any process to upload image from rommon ? or i need to upload image from
another same router ? i have another router with same model installed same image .. can you please tell me the process of recovery..
Upgrade ROMMON initialized
Entering rommon> prompt after several failed attempts to boot an IOS image.
Please check your internal/external flash drives for the correct IOS image
and issue 'reset' at the rommon> prompt to re-try the boot process.
rommon 1 >
rommon 1 > dir flash:
program load complete, entry point: 0x8000f000, size: 0xcb80
Directory of flash:
8481 1953 -rw- c2800nm-ipvoicek9-mz.151-4.M10.bin
14678 0 drw- Desktops
14950 0 drw- Phone
rommon 2 > boot flash:c2800nm-ipvoicek9-mz.151-4.M10.bin
loadprog: bad file magic number: 0x0
boot: cannot load "flash:c2800nm-ipvoicek9-mz.151-4.M10.bin"
rommon 3 >
johnlloyd_13
Level 9
Level 9
hi,
you can use the tftpdnld command in ROMMON.
make sure your config register is set to 0x2102.
you can verify it via show version.
rommon 1 > IP_ADDRESS=192.168.1.2
rommon 2 > IP_SUBNET_MASK=255.255.255.0
rommon 3 > DEFAULT_GATEWAY=192.168.1.1
rommon 4 > TFTP_SERVER=192.168.1.1
rommon 5 > TFTP_FILE=c2800nm-ipvoicek9-mz.151-4.M10.bin
rommon 6 > tftpdnld
