01-07-2014 11:19 PM - edited 03-04-2019 10:01 PM
I'm trying to do transparent bridging with the following setup but im unable to pass traffic from R1 to the PE router. My goal is to use R2 as a L2 bridge to get connectivity between R1 and PE1. R1 doesn't have the necessary module hence this setup and i dont manage the PE side..
Just testing this to avoid paying on having extra hardware:)
R1 F0/0 <> F0/0 R2 Multilink1 (s1/0,s1/1) <> Multilink1 (s1/0, s1/1) PE1
1.1.1.1/30 1.1.1.2/30
First issue that I see is the IP address on the Multilink on the PE side. I have the multilink interface UP between R2 and PE, 1.1.1.0/30 is not being installed as a connected interface on the routing table. Not sure how can go around this. Below is the config for reference.
Is this setup even possible? Or i'm missing something? Any help will be much appreciated. Thanks in advanced!
R1:
interface FastEthernet0/0
ip add 1.1.1.1 255.255.255.252
R2:
bridge irb
bridge 1 protocol ieee
bridge-group 1
interface Multilink1
no ip address
ppp multilink
ppp multilink group 1
bridge-group 1
interface Serial1/0
no ip address
encapsulation ppp
serial restart-delay 0
ppp multilink
interface Serial1/1
no ip address
encapsulation ppp
ppp multilink
PE1:
ip address 1.1.1.2 255.255.255.252
ppp multilink
interface Serial1/0
no ip address
encapsulation ppp
ppp multilink
interface Serial1/1
no ip address
encapsulation ppp
ppp multilink
01-08-2014 07:20 AM
There are parts of your post that are not clear to me. In particular in which routing table are you expecting to see the /30 network? Are you looking on R1 (where I would expect it to be) or on R2 (where the expected behavior is that the subnet will not be in the routing table since R2 is bridging that subnet and not routing it).
If I were doing this I probably would not use irb on R2. irb gives you the ability to interface the bridged domain to the routed domain. But based on what you have shown us there is not a routed domain on R2. I would suggest that you configure no ip routing on R2, remove the bridge irb command, and use the rest of the config as you have it.
Rick
01-08-2014 04:36 PM
Thanks for the inputs Rick! Sorry if I was not clear enough on my post. I'm doing this on the lab in preparation so I can expect what the behavior of the PE router will be during the cutover. The /30 network which im not seeing being installed is on the routing table of my PE1 router. I was expecting that since the Multilink is UP on the PE1 router, the /30 will be installed as a connected Interface on PE1 routing table but that wasn't the case. The Multilink interface on PE1 is still waiting reply from the Multilink interface on R2 to agree on the IP address. Since the IP address is configured on R1's Ethernet interface and R2 is only in bridge mode, R2 is not sending any acknowledgement back to PE1. Is there any workaround on this behaviour? Thanks again!
- Liam
PE1
PE1(config)#int mul1
PE1(config-if)#ip address 1.1.1.2 255.255.255.252
PE1(config-if)#
*Mar 1 05:20:47.566: Mu1 IPCP: O CONFREQ [Listen] id 7 len 10
*Mar 1 05:20:47.566: Mu1 IPCP: Address 1.1.1.2 (0x030601010102)
*Mar 1 05:20:47.570: Se1/1 MLP: O frag C0000040 size 20 encsize 4
*Mar 1 05:20:47.570: Se1/1 MLP: O data FF03 003D C000 0040 8021 0107 000A 0306
*Mar 1 05:20:47.574: Se1/1 MLP: I ppp LCP (C021) size 20 encsize 4
*Mar 1 05:20:47.578: Se1/1 MLP: I data FF03 C021 0807 0010 8021 0107 000A 0306
*Mar 1 05:20:47.578: RT: is_up: Multilink1 0 state: 4 sub state: 1 line: 0 has_route: True
*Mar 1 05:20:47.582: RT: is_up: Multilink1 0 state: 4 sub state: 1 line: 0 has_route: True
*Mar 1 05:20:47.586: Mu1 LCP: I PROTREJ [Open] id 7 len 16 protocol IPCP (0x80210107000A030601010102)
*Mar 1 05:20:47.586: Mu1 IPCP: State is Closed
*Mar 1 05:20:47.590: Mu1 IPCP: State is Listen
PE1# ping 1.1.1.1
Sending 5, 100-byte ICMP Echos to 1.1.1.1, timeout is 2 seconds:
*Mar 1 05:41:09.746: IP: s=1.1.1.2 (local), d=1.1.1.1, len 100, unroutable.
R2 (bridge)
*Mar 1 05:27:20.614: Mu1 PPP: Outbound ieee-st packet dropped
*Mar 1 05:27:21.046: Mu1 IPCP: I CONFREQ [Not negotiated] id 8 len 10
*Mar 1 05:27:21.046: Mu1 IPCP: Address 1.1.1.2 (0x030601010102)
*Mar 1 05:27:21.046: Mu1 LCP: O PROTREJ [Open] id 8 len 16 protocol IPCP (0x80210108000A030601010102)
R1
R1# ping 1.1.1.2
Sending 5, 100-byte ICMP Echos to 1.1.1.2, timeout is 2 seconds:
*Mar 1 05:13:11.986: IP: tableid=0, s=1.1.1.1 (local), d=1.1.1.2 (FastEthernet0/0), routed via RIB
*Mar 1 05:13:11.986: IP: s=1.1.1.1 (local), d=1.1.1.2 (FastEthernet0/0), len 100, sending
*Mar 1 05:13:11.990: IP: s=1.1.1.1 (local), d=1.1.1.2 (FastEthernet0/0), len 100, encapsulation failed.
01-08-2014 07:20 PM
Liam
Your response provides information that is quite helpful. I have done configurations that did bridging between Ethernet and serial interfaces which worked. But I do not believe that I have ever done one that involved a multilink interface. And based on your information the multilink in the bridge group may create a problem. I believe that the issue is that your PE1 router is depending on IPCP to negotiate/confirm the IP address on the interface. But since the multilink on R2 has no IP address it can not complete the IPCP negotiation.
Rick
01-12-2014 04:05 PM
Yeah the IPCP negotiation between R2 and PE1 is problem. Works fine if R2 multilink has an IP but defeats the purpose of it being a L2 device only. Thanks Rick.
01-09-2014 02:18 PM
On PE1 configure the multilink for bridging same as R2, then configure IRB with a BVI interface and put the address on the BVI.
Here is a sample relevant configuration. I tried it out on three random routers and the three addresses can ping each other.
The BVI on r200 is superfluous for you but it's handy for checking reachability.
r202#
interface Ethernet0/0
ip address 10.0.0.202 255.255.255.0
end
r200#
bridge irb
no ip address
bridge-group 1
interface BVI1
ip address 10.0.0.200 255.255.255.0
no ip address
ppp multilink
bridge-group 1
interface Serial2/0
no ip address
encapsulation ppp
ppp multilink
interface Serial3/0
no ip address
encapsulation ppp
ppp multilink
bridge 1 route ip
r200#
r201#
bridge irb
interface BVI1
ip address 10.0.0.201 255.255.255.0
no ip address
ppp multilink
bridge-group 1
interface Serial2/0
no ip address
encapsulation ppp
ppp multilink
interface Serial3/0
no ip address
encapsulation ppp
ppp multilink
bridge 1 route ip
r201#
01-12-2014 04:00 PM
Hi Margalla,
Thanks for the inputs apparently I don't manage the PE router which I stated before and i don't think my SP will configure bridging on their PEs.
