11-16-2009 03:36 AM - edited 03-04-2019 06:43 AM
hi,
our branch office is connected to the head office via one E1 link(point to point) and communicates through EIGRP. Now we have got another E1 link and we need to club both of the lines( which are on different interfaces ). As per the documentation both the interfaces of the two routers should be in the same subnet. How can we configure two wan interfaces within the same subnet and how do we resolve the IP overlap issue.
11-16-2009 04:14 AM
Interface not need to be in the same subnet.
You can report the documentation error using the feedback form.
Note if you are the end user, recommend you hire a networking professional for best results.
11-16-2009 04:19 AM
thanks for the reply..
if the interfaces need not be in the same subnet, then how do we bundle them.
Is it possible to do such thing.?
11-16-2009 04:22 AM
EIGRP does not bundle anything, it is a routing protocol.
Again, since evidently you are not a network engineer, I recommend you give this task to a certified one.
