C1111-8PLTE / LTE Troubles
solarwinds123
I'll keep this brief as possible; I'm having trouble bring up my LTE / Cell0/2/0 connection on my C1111-8PLTE.
I can get the connection up with nearly no action by me on a fresh start (no startup-config). After adding a static route, I can pass traffic in/out the LTE connection. Once I reboot, Cell0/2/0 connection does not come back up with a valid IP.
Router#erase startup-config
Erasing the nvram filesystem will remove all configuration files! Continue? [confirm]
[OK]
Erase of nvram: complete
Router#
Router#write erase
[OK]
Router#
[hard power cycle]
--- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]: no
Would you like to terminate autoinstall? [yes]:
Press RETURN to get started!
[snip]
*Oct 22 18:18:30.572: %LINK-3-UPDOWN: Interface Cellular0/2/0, changed state to down
*Oct 22 18:18:30.572: %LINK-3-UPDOWN: Interface Cellular0/2/1, changed state to down
*Oct 22 18:18:35.695: %SYS-5-RESTART: System restarted --
Cisco IOS Software [Everest], ISR Software (ARMV8EB_LINUX_IOSD-UNIVERSALK9_IAS-M), Version 16.6.4, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Sun 08-Jul-18 01:38 by mcpre
*Oct 22 18:18:38.270: %SYS-6-BOOTTIME: Time taken to reboot after reload = 352 seconds
CRYPTO_PKI: setting trustpoint policy for TP-self-signed-3246394489 to specify TP-self-signed-3246394489 keypair usage% Generating 2048 bit RSA keys, keys will be non-exportable...
[OK] (elapsed time was 1 seconds)
Failed to generate persistent self-signed certificate.
Secure server will use temporary self-signed certificate.
*Oct 22 18:18:57.462: %SSH-5-ENABLED: SSH 1.99 has been enabled
*Oct 22 18:18:58.125: %PNP-6-PNP_DISCOVERY_STOPPED: PnP Discovery stopped (Config Wizard)
*Oct 22 18:19:22.572: %CELLWAN-5-SIM_DETECT_START: [Cellular0/2/0]: SIM presence detection starts !!
*Oct 22 18:19:25.200: %CELLWAN-6-SIM_PRESENT: [Cellular0/2/0]: SIM is present in Slot 0
*Oct 22 18:19:25.200: %CELLWAN-5-SIM_DETECT_COMPLETE: [Cellular0/2/0]: SIM presence detection has completed !!
*Oct 22 18:20:30.681: %CELLWAN-2-MODEM_UP: Modem in slot 0/2 is now UP
*Oct 22 18:20:30.883: %CELLWAN-2-MODEM_RADIO: Cellular0/2/0 Modem radio has been turned on
*Oct 22 18:20:32.902: %LINK-3-UPDOWN: Interface Cellular0/2/0, changed state to up
*Oct 22 18:20:33.902: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cellular0/2/0, changed state to up
Router>
Router>
Router>en
Router#
Router#
Router#show ip int brief
GigabitEthernet0/0/0 unassigned YES unset administratively down down
GigabitEthernet0/0/1 unassigned YES unset administratively down down
GigabitEthernet0/1/0 unassigned YES unset down down
GigabitEthernet0/1/1 unassigned YES unset down down
GigabitEthernet0/1/2 unassigned YES unset down down
GigabitEthernet0/1/3 unassigned YES unset down down
GigabitEthernet0/1/4 unassigned YES unset down down
GigabitEthernet0/1/5 unassigned YES unset down down
GigabitEthernet0/1/6 unassigned YES unset down down
GigabitEthernet0/1/7 unassigned YES unset down down
Cellular0/2/0 107.126.xxx.xx YES IPCP up up
Cellular0/2/1 unassigned YES unset down down
Vlan1 unassigned YES unset up down
Router#
Router#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Router(config)#ip route 0.0.0.0 0.0.0.0 cellular 0/2/0
Router(config)#end
Router#
Router#
*Oct 22 18:20:53.901: %SYS-5-CONFIG_I: Configured from console by console
Router#
Router#ping 8.8.8.8
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 40/55/68 ms
Router#
(note - this output was taken from a previous write erase cycle, system time is different)
Router#show int cell 0/2/0
Cellular0/2/0 is up, line protocol is up
Hardware is LTE Adv TSN CAT6 - Multimode LTE/DC-HSPA+/HSPA+/HSPA/UMTS/EDGE/GPRS
Internet address is 107.126.xxx.xx/32
MTU 1500 bytes, BW 50000 Kbit/sec, DLY 20000 usec,
Encapsulation HDLC, loopback not set
Keepalive not supported
Last input never, output 00:00:00, output hang never
Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
10 packets output, 688 bytes, 0 underruns
0 unknown protocol drops
0 carrier transitions
Router#
Router#sh cellular 0/2/0 profile
Profile 1 = ACTIVE* **
PDP Type = IPv4v6
PDP address = 107.126.xxx.xx
Access Point Name (APN) =
Authentication = None
Primary DNS address = 166.216.138.41
Secondary DNS address = 166.216.138.42
Profile 2 = INACTIVE
* - Default profile
** - LTE attach profile
Configured default profile for active SIM 0 is profile 1.
Router#
Router#
Router#show cell 0/2/0 connection
Profile 1, Packet Session Status = ACTIVE
Cellular0/2/0:
Data Packets Transmitted = 9 , Received = 19
Data Transmitted = 660 bytes, Received = 1633 bytes
IP address = 107.126.xxx.xx
Profile 2, Packet Session Status = INACTIVE
Profile 3, Packet Session Status = INACTIVE
Profile 4, Packet Session Status = INACTIVE
Profile 5, Packet Session Status = INACTIVE
Profile 6, Packet Session Status = INACTIVE
Profile 7, Packet Session Status = INACTIVE
Profile 8, Packet Session Status = INACTIVE
Profile 9, Packet Session Status = INACTIVE
Profile 10, Packet Session Status = INACTIVE
Profile 11, Packet Session Status = INACTIVE
Profile 12, Packet Session Status = INACTIVE
Profile 13, Packet Session Status = INACTIVE
Profile 14, Packet Session Status = INACTIVE
Profile 15, Packet Session Status = INACTIVE
Profile 16, Packet Session Status = INACTIVE
Router#
Router#
Router#show cell 0/2/0 all
Hardware Information
Modem Firmware Version = SWI9X30C_02.24.05.06
Modem Firmware built = 2017/05/19 06:23:09
Hardware Version = 1.0
Device Model ID: EM7455
International Mobile Subscriber Identity (IMSI) = 31003000525xxxx
International Mobile Equipment Identity (IMEI) = 35612907049xxxx
Integrated Circuit Card ID (ICCID) = 8901030330005251xxxx
Mobile Subscriber Integrated Services
Digital Network-Number (MSISDN) =
Modem Status = Modem Online
Current Modem Temperature = 30 deg C
PRI SKU ID = 1102526, PRI version = 002.026_000, Carrier = Generic
OEM PRI version = 007
Profile Information
PDP Type = IPv4v6
* - Default profile
Data Connection Information
Cellular0/2/0:
Network Information
Current System Time = Fri Oct 22 15:41:5 2021
Current Service Status = Normal
Current Service = Packet switched
Current Roaming Status = Home
Network Selection Mode = Automatic
Network = AT&T
Mobile Country Code (MCC) = 310
Mobile Network Code (MNC) = 410
Packet switch domain(PS) state = Attached
LTE Carrier Aggregation state = Deconfigured
Registration state(EMM) = Registered
EMM Sub State = Normal Service
Tracking Area Code (TAC) = 16668
Cell ID = 54621056
Radio Information
Radio power mode = online
LTE Rx Channel Number = 675
LTE Tx Channel Number = 18675
LTE Band = 2
LTE Bandwidth = 15 MHz
Current RSSI = -51 dBm
Current RSRP = -74 dBm
Current RSRQ = -6 dB
Current SNR = 30.0 dB
Physical Cell Id = 499
Number of nearby cells = 1
Idx PCI (Physical Cell Id)
1 499
Radio Access Technology(RAT) Preference = AUTO
Radio Access Technology(RAT) Selected = LTE
Modem Security Information
Active SIM = 0
SIM switchover attempts = 0
Card Holder Verification (CHV1) = Disabled
SIM Status = OK
SIM User Operation Required = None
Number of CHV1 Retries remaining = 3
Cellular Firmware List
Idx Carrier FwVersion PriVersion Status
1 ATT 02.24.05.06 002.027_000 Inactive
2 BELL 02.24.05.06 001.005_000 Inactive
3 GENERIC 02.24.05.06 002.026_000 Active
4 ROGERS 02.24.05.06 001.005_000 Inactive
5 SPRINT 02.26.01.00 002.029_000 Inactive
6 TELUS 02.24.05.06 001.005_000 Inactive
7 US-Cellular 02.24.05.06 000.003_000 Inactive
8 VERIZON 02.24.05.06 002.034_000 Inactive
9 VODAFONE 02.24.03.00 001.001_000 Inactive
Firmware Activation mode : AUTO
GPS Information
GPS Info
GPS Feature: enabled
GPS Mode Configured: not configured
GPS Status: NMEA Disabled
SMS Information
Incoming Message Information
SMS stored in modem = 1
SMS archived since booting up = 0
Total SMS deleted since booting up = 0
Storage records allocated = 25
Storage records used = 1
Number of callbacks triggered by SMS = 0
Number of successful archive since booting up = 0
Number of failed archive since booting up = 0
Outgoing Message Information
Total SMS sent successfully = 0
Total SMS send failure = 0
Number of outgoing SMS pending = 0
Last Outgoing SMS Status = SUCCESS
Copy-to-SIM Status = 0x0
Send-to-Network Status = 0x0
Report-Outgoing-Message-Number:
Reference Number = 0
Result Code = 0x0
Diag Code = 0x0 0x0 0x0 0x0 0x0
SMS Archive URL =
Error Information
This command is not supported on 4G modems.
Modem Crashdump Information
Modem crashdump logging: off
Router#
Router#
Router#
Router#write
Building configuration...
[OK]
*Oct 22 18:21:09.624: %SYS-2-PRIVCFG_ENCRYPT: Successfully encrypted private config file
Router#
Router#reload
Proceed with reload? [confirm]
*Oct 22 18:21:15.259: %SYS-5-RELOAD: Reload requested by console. Reload Reason: Reload Command.
[device reloads]
second boot:
[snip]
*Oct 22 18:25:57.149: %LINK-3-UPDOWN: Interface GigabitEthernet0/1/0, changed state to down
*Oct 22 18:25:57.193: %LINK-3-UPDOWN: Interface GigabitEthernet0/1/1, changed state to down
*Oct 22 18:25:57.200: %LINK-3-UPDOWN: Interface GigabitEthernet0/1/2, changed state to down
*Oct 22 18:25:57.218: %LINK-3-UPDOWN: Interface GigabitEthernet0/1/3, changed state to down
*Oct 22 18:25:57.230: %LINK-3-UPDOWN: Interface GigabitEthernet0/1/4, changed state to down
*Oct 22 18:25:57.234: %LINK-3-UPDOWN: Interface GigabitEthernet0/1/5, changed state to down
*Oct 22 18:25:57.241: %LINK-3-UPDOWN: Interface GigabitEthernet0/1/6, changed state to down
*Oct 22 18:25:57.249: %LINK-3-UPDOWN: Interface GigabitEthernet0/1/7, changed state to down
*Oct 22 18:25:57.970: %LINK-3-UPDOWN: Interface Cellular0/2/0, changed state to down
*Oct 22 18:25:57.974: %LINK-3-UPDOWN: Interface Cellular0/2/1, changed state to down
*Oct 22 18:26:50.118: %CELLWAN-5-SIM_DETECT_START: [Cellular0/2/0]: SIM presence detection starts !!
*Oct 22 18:26:52.734: %CELLWAN-6-SIM_PRESENT: [Cellular0/2/0]: SIM is present in Slot 0
*Oct 22 18:26:52.734: %CELLWAN-5-SIM_DETECT_COMPLETE: [Cellular0/2/0]: SIM presence detection has completed !!
*Oct 22 18:27:58.226: %CELLWAN-2-MODEM_UP: Modem in slot 0/2 is now UP
*Oct 22 18:27:58.427: %CELLWAN-2-MODEM_RADIO: Cellular0/2/0 Modem radio has been turned on
Router>
Router>
Router>en
Router#
Router#
GigabitEthernet0/0/0 unassigned YES NVRAM administratively down down
GigabitEthernet0/0/1 unassigned YES NVRAM administratively down down
Cellular0/2/0 unassigned YES NVRAM down down
Cellular0/2/1 unassigned YES NVRAM down down
Router#
Router#
Router#ping 8.8.8.8
% Unrecognized host or address, or protocol not running.
Router#
Router#
Cellular0/2/0 is down, line protocol is down
