C2821 package process
jj-zhou
Hi Netpros:
I have C2821 to use EoSDH link on fix GE port , I concern that dose it process real 1000M traffic when running routing protocol and Mpls etc..
thru it's line speed forward in documentation.
thanks
Herman
paolo bevilacqua
Search "router performance" and you will finf many posts with a document.
However in short, the 2821 cannot to gigabit wire rate and not even an half of it.
HI :
thanks fast response , but may I have a practice value or exact test result to refer , less than 500M , it means based 1500Byte or what's testing environment.
thanks
Herman
Serarch the document here and has all the info in there.
