C3850-48T log
heyjunsun
hello
A log occurred while using the product
May I know what this means?
Feb  3 09:08:58.909 KST: %IOSXE-4-PLATFORM: Switch 1 R0/0: kernel: EDAC DEVICE1: CE: octeon_l2c_err instance: l2c0 block: l2c1 'L2D Single bit error (corrected):type:0, syn:0x0, way:119363'
Feb  3 09:08:58.909 KST: %IOSXE-4-PLATFORM: Switch 1 R0/0: kernel: EDAC DEVICE1: CE: octeon_l2c_err instance: l2c0 block: l2c1 'VBF Single bit error (corrected):type:0, syn:0x0, way:119363'
Feb  3 09:08:59.909 KST: %IOSXE-4-PLATFORM: Switch 1 R0/0: kernel: EDAC DEVICE1: CE: octeon_l2c_err instance: l2c0 block: l2c1 'L2D Single bit error (corrected):type:0, syn:0x54, way:129731'
Feb  3 09:08:59.909 KST: %IOSXE-4-PLATFORM: Switch 1 R0/0: kernel: EDAC DEVICE1: CE: octeon_l2c_err instance: l2c0 block: l2c1 'VBF Single bit error (corrected):type:0, syn:0x54, way:129731'
Can I know how to fix what this log means or its impact?
9 Replies 9
Leo Laohoo
Reboot the switch first.
hello Leo
Our company wants to know the cause of the problem before solving it.
This is because I think we need to know the cause to prevent it from happening again afterwards.
What firmware is the switch running on and what is the uptime of the switch/stack?
Switch version is
16.6.5 CAT3K_CAA-UNIVERSALK9
uptime is 10 weeks, 2 days, 11 hours, 57 minutes
The error message is from the Kernel of the OS.
Once or twice is OK, however, if it is happening a lot reboot or upgrade the firmware.
Is this message OS Kernal defect?
I'd reboot switch 1.
I know how to fix it.(Switch reboot or firmware upgrate)
Is the cause OS Kernal?
