01-24-2022 01:29 AM
GOod Day All,
We have Cisco C3850 running ipbase license recently we decided to run BGP protocol for that we need ipservices license. Do i need to buy new license or i have already that i just need to activate using right-to-use?
Cisco IOS Software [Denali], Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 16.3.5b, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Thu 02-Nov-17 11:07 by mcpre
Technology Package License Information:
Technology-package Technology-package
Current Type Next reboot
ipbasek9 Permanent ipbasek9
01-24-2022 01:47 AM
Correct.
You need IP services license.
You can enable evaluation license.
You can use it 90 days.
During this period you can buy an IP services license and install it.
Ventsi
01-24-2022 02:01 AM
You have only ipbasek9 License, but if you have ipservice License you can use it, you can enable as mentioned below document :
https://blog.router-switch.com/2016/10/how-to-activateupgrade-c3850-ip-base-license-to-ip-services/
01-24-2022 02:19 AM
01-24-2022 02:53 AM
yes correct - enable and test it.
