C4506 Switch Chassis Error Message.. Need help
cindylee27
Hi Experts,
I got this error message when trying to install one card at C4506 New core switch.
Is it due to IOS not compatible and which IOS I should use to resolve this issue?
Error message:
Jul 30 00:13:19.823 gmt: %C4K_CHASSIS-3-UNKNOWNLINECARD: Unknown module (Field Replaceable Unit minor type 351) in slot 3
Thanks a lot,
cindy
Goutam Sanyal
Level 4
Level 4
Hi Cindy Lee,
As per Cisco:
%C4K_CHASSIS-3-UNKNOWNLINECARD: Unknown module (Field Replaceable Unit minor type [dec]) in slot [dec]
The module's serial EEPROM was readable, and your software image does not recognize this module. A software upgrade is necessary.
Recommended Action: Upgrade the software to a version that is compatible with the module.
Goutam
Hi Goutam,
Thanks for your reply..
Problem is Do you know which IOS version I should go for?
Really appreciate your help.
cindy
Hi Cindy,
Can you post the following?
1. sh ver
2. sh inventory
3. sh idprom all
4. sh bootflash: all
Goutam,
Pls rate all helpful posts
