C897VAG-LTE-GA-K9 - Cant find how to connect gi interfaces to internet
RokasK
Hello fellow networkers
I have an issue with my newly purchased relatively old router. I have to confess that I feel embarrassed that I have to post this kind question over here as I recently past my CCNA.
So the issue is that I can ping internet from router HOWEVER I can not connect any device to internet via Gi1 interface
My aim is to add gi0-1 to vlan 2
Thank you in advance
My running-config below Thank you for your help in advice
outer#show running-config
Building configuration...
Current configuration : 2519 bytes
! Last configuration change at 23:14:53 UTC Thu May 14 2020
version 15.5
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ethernet lmi ce
ip cef
no ipv6 cef
chat-script lte "" "AT!CALL" TIMEOUT 20 "OK"
license udi pid C897VAG-LTE-GA-K9 sn FCZ194393LQ
vtp mode transparent
controller VDSL 0
controller Cellular 0
lte modem link-recovery rssi onset-th lte modem linkor-timer 20
-recovery wait-timer 10
e modem link-recovery debounce-count 6
--!ore-- name MEDIA !
track 234 ip sla 1 re!
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface Cellular0
ip address negotiated
encapsulation slip
dialer in-band
dialer string lte
dialer-group 1
interface Cellular1
no ip address
encapsulation slip
interface Ethernet0
no ip address
shutdown
interface GigabitEthernet0
no ip address
interface GigabitEthernet1
switchport access vlan 2
no ip address
interface GigabitEthernet2
no ip address
interface GigabitEthernet3
no ip address
interface GigabitEthernet4
no ip address
interface GigabitEthernet5
no ip address
interface GigabitEthernet6
no ip address
interface GigabitEthernet7
no ip address
interface GigabitEthernet8
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
no ip address
interface Vlan2
ip address 192.168.1.1 255.255.255.248
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 Cellular0
ip route 192.168.1.0 255.255.255.248 Cellular0
ip sla 1
icmp-echo 10.1.1.1 source-interface Cellular0
frequency 5
ip sla schedule 1 life forever start-time now
dialer-list 1 protocol ip list 1
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
no modem enable
line aux 0
line 2
no activation no exec r transport p transport input all stopbits 1
line 3
script dialer lte
no exec
rxspeed 100000000
txspeed 50000000
line 8
no exec
rxspeed 100000000 txspeed 50000000 line vty 0 4
login
transport input none
scheduler allocate 20000 1000
end
how is the TV getting an IP address, through DHCP ? Try and configure the router as DHCP server by adding the lines in bold:
Current configuration : 2475 bytes
version 15.5
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ethernet lmi ce
ip cef
no ipv6 cef
ip dhcp excluded-address 192.168.1.1
ip dhcp excluded-address 192.168.2.1
ip dhcp pool VLAN1
network 192.168.2.0 255.255.255.0
default-router 192.168.2.1
dns-server 8.8.8.8
ip dhcp pool VLAN2
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 8.8.8.8
controller VDSL 0
lte modem link-recovery rssi onset-threshold -110
lte modem link-recovery monitor-timer 20
lte modem link-recovery wait-timer 10
lte modem link-recovery debounce-count 6
vlan 2
name MEDIA
interface ATM0
no ip address
shutdown
interface Cellular0
ip nat outside
ip virtual-reassembly in
encapsulation slip
dialer in-band
dialer string lte
dialer-group 1
interface Cellular1
no ip address
encapsulation slip
interface Ethernet0
no ip address
shutdown
no ip address
no ip address
speed 1000
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
ip address 192.168.2.1 255.255.255.248
ip nat inside
interface Vlan2
ip nat inside
no ip http server
ip nat inside source list 1 interface Cellular0 overload
dialer-list 1 protocol ip permit
--> no access-list 1 permit any
access-list 1 permit 192.168.0.0 0.0.255.255
control-plane
line con 0
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
stopbits 1
line 3
script dialer lte
no exec
line 8
no exec
line vty 0 4
login
transport input none!
end
14 Replies 14
make the changes marked in bold to your configuration:
version 15.5
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ethernet lmi ce
ip cef
no ipv6 cef
controller VDSL 0
interface ATM0
no ip address
shutdown
interface Cellular0
--> ip nat outside
encapsulation slip
dialer in-band
dialer string lte
dialer-group 1
interface Cellular1
no ip address
encapsulation slip
interface Ethernet0
no ip address
shutdown
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
no ip address
interface Vlan2
--> ip nat inside
no ip http server
--> no ip route 192.168.1.0 255.255.255.248 Cellular0
--> ip nat inside source list 1 interface Cellular0 overload
ip sla 1
frequency 5
--> access-list 1 permit 192.168.1.0 0.0.0.7
control-plane
line con 0
no modem enable
line aux 0
line 2
line 3
script dialer lte
no exec
rxspeed 100000000
txspeed 50000000
line 8
no exec
login
end
Does not working though
Router#show ip int brief
ATM0 unassigned YES NVRAM administratively down down
Cellular0 unassigned YES NVRAM up up
Cellular1 unassigned YES unset down down
Ethernet0 unassigned YES NVRAM administratively down down
GigabitEthernet0 unassigned YES unset down down
GigabitEthernet1 unassigned YES unset up up
GigabitEthernet2 unassigned YES unset down down
GigabitEthernet3 unassigned YES unset down down
GigabitEthernet4 unassigned YES unset down down
GigabitEthernet5 unassigned YES unset down down
GigabitEthernet6 unassigned YES unset down down
GigabitEthernet7 unassigned YES unset down down
GigabitEthernet8 unassigned YES NVRAM administratively down down
NVI0 10.10.10.1 YES unset up up
Vlan1 unassigned YES unset down down
Vlan2 192.168.1.1 YES NVRAM up up
Router#show ip nat statistics
Total active translations: 0 (0 static, 0 dynamic; 0 extended)
Peak translations: 0
Outside interfaces:
Cellular0
Inside interfaces:
Vlan2
Hits: 0 Misses: 0
CEF Translated packets: 0, CEF Punted packets: 0
Expired translations: 0
Dynamic mappings:
-- Inside Source
[Id: 1] access-list 1 interface Cellular0 refcount 0
Total doors: 0
Appl doors: 0
Normal doors: 0
Queued Packets: 0
post your running configuration again with the changes you have implemented...
actually, with your current configuration, only whatever is connected to interface GigabitEthernet1 will be able to access the Internet. If you want to access the Internet from the other ports, configure the below:
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
Router#show running-config
version 15.5
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ethernet lmi ce
ip cef
no ipv6 cef
multilink bundle-name authenticated !
chat-script lte "" "AT!CALL" TI!
license udi pid C897VAG-LTE-GA-K9 s!
controller VDSL 0
lte modem link-recovery rssi onset- lte modem link-recovery monitor-timer 20
vlan 2
name MEDIA
interface ATM0
no ip address
shutdown
interface Cellular0
ip nat outside
encapsulation slip
dialer in-band
dialer string lte
dialer-group 1
interface Cellular1
no ip address
encapsulation slip
interface Ethernet0
no ip address
shutdown
no ip address
no ip address
speed 1000
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
ip nat inside
ip nat enable
interface Vlan2
ip address 192.168.1.1 255.255.255.8
ip n ip virtual-reassembly in
no ip http server
control-plane
line con 0
no modem enable
line aux 0
line 2
no exec
transport input all
stopbits 1
line 3
script dialer lte
no exec
rxspeed 100000000
txspeed 50000000
line 8
no exec
line vty 0 4
login
end
version 15.5
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ethernet lmi ce
ip cef
no ipv6 cef
controller VDSL 0
vlan 2
name MEDIA
interface ATM0
no ip address
shutdown
interface Cellular0
ip nat outside
encapsulation slip
dialer in-band
dialer string lte
dialer-group 1
interface Cellular1
no ip address
encapsulation slip
interface Ethernet0
no ip address
shutdown
no ip address
no ip address
speed 1000
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
ip nat inside
--> no ip nat enable
interface Vlan2
--> ip nat inside
no ip http server
--> access-list 1 permit 192.168.0.0 0.0.255.255
control-plane
line con 0
no modem enable
line aux 0
line 2
no exec
transport input all
stopbits 1
line 3
script dialer lte
no exec
rxspeed 100000000
txspeed 50000000
line 8
no exec
line vty 0 4
login
end
OK so it doesnt work and on top of that my gi1 in vlan 2 is dead as even no led light when cable inserted.
In gi3 vlan 1 (native) cable connected to tv and it says "can not connect to internet via ethernet"
Config
version 15.5
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ethernet lmi ce
ip cef
no ipv6 cef
controller VDSL 0
vlan 2
name MEDIA
interface ATM0
no ip address
shutdown
interface Cellular0
ip nat outside
encapsulation slip
dialer in-band
dialer string lte
dialer-group 1
interface Cellular1
no ip address
encapsulation slip
interface Ethernet0
no ip address
shutdown
no ip address
no ip address
speed 1000
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
ip nat inside
interface Vlan2
ip nat inside
no ip http server
control-plane
line con 0
no modem enable
line aux 0
line 2
no exec
transport input all
stopbits 1
line 3
script dialer lte
no exec
line 8
no exec
line vty 0 4
login
end
Gi1 vlan2 cable connected no LED light on router (it was before)
Router#show int gi1
GigabitEthernet1 is down, line protocol is down
Hardware is Gigabit Ethernet, address is 84b2.6111.e028 (bia 84b2.6111.e028)
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Auto-duplex, 1000Mb/s
Last input never, output never, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
int gi3 vlan1 (native) connected to TV
Router#show int gi3
GigabitEthernet3 is up, line protocol is up
Hardware is Gigabit Ethernet, address is 84b2.6111.e02a (bia 84b2.6111.e02a)
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
Full-duplex, 100Mb/s
176 packets input, 75832 bytes, 0 no buffer
Received 99 broadcasts (77 multicasts)
394 packets output, 36689 bytes, 0 underruns
1 lost carrier, 0 no carrier, 0 pause output
Cellular0 10.99.197.19 YES IPCP up up
GigabitEthernet1 unassigned YES unset down down
GigabitEthernet3 unassigned YES unset up up
Vlan1 192.168.2.1 YES NVRAM up up
Vlan2 192.168.1.1 YES NVRAM down down
Peak translations: 1, occurred 00:10:18 ago
Outside interfaces:
Cellular0
Inside interfaces:
Vlan1, Vlan2
Hits: 9 Misses: 0
Dynamic mappings:
-- Inside Source
Total doors: 0
Appl doors: 0
Normal doors: 0
Queued Packets: 0
Could it be because of cell 0 profile mismatch? I mean ping works but thats ICMP?
what exactly do you have connected on port 3, a tv ? Does that device get an IP address ?
The cellular is fine I guess. Try and ping 8.8.8.8 from the router, does that work ?
Hello I sorted the dead connection on gi3 it was the speed 1000 command even though all interfaces are gbit :/
anyway on the tv shows
ip 169.254.181.175 / 255.255.0.0
no internet via ethernet
I dont understand I checked nat couple of times. could it be that I need start some internal routing protocol? because I can ping outside etc. >?
there is no internet from any gib port
version 15.5
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ethernet lmi ce
ip cef
no ipv6 cef
ip dhcp pool VLAN1
dns-server 8.8.8.8
ip dhcp pool VLAN2
dns-server 8.8.8.8
controller VDSL 0
vlan 2
name MEDIA
interface ATM0
no ip address
shutdown
interface Cellular0
ip nat outside
encapsulation slip
dialer in-band
dialer string lte
dialer-group 1
interface Cellular1
no ip address
encapsulation slip
interface Ethernet0
no ip address
shutdown
no ip address
no ip address
speed 1000
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
ip nat inside
interface Vlan2
ip nat inside
no ip http server
control-plane
line con 0
no modem enable
line aux 0
line 2
no exec
transport input all
stopbits 1
line 3
script dialer lte
no exec
line 8
no exec
line vty 0 4
login
end
Thank you finally it works!
Its quite strange though that I HAVE TO implement dhcp but anyway its a good experience for me
how would the tv get an IP address otherwise, is it possible to assign a static IP address ? Just out of curiosity, what brand/model is the tv ?
[LG]webOS TV SK8100PLA im not sure can I set manual IP
