Cable Modem and 2960X
Alex Rich
I am able to ping google from the switch. The switch is correctly handing out addresses to client connected. I am unable to ping from the data vlan (3). I am sure this is something simple. The default gateway and subnet changes on the local side of the modem every time reconnect the interface (g1/0/24). I am unable to setup an ip route 0.0.0.0 0.0.0.0 . If I do and point it at vlan 2 (since I have no address to use) I am no longer able to connect to the outside world. Any thoughts?
switch#sh run
Building configuration...
Current configuration : 32098 bytes
! Last configuration change at 00:44:01 UTC Wed Nov 23 2016
! NVRAM config last updated at 00:42:24 UTC Wed Nov 23 2016
version 15.2
no service pad
hostname switch
boot-start-marker
boot-end-marker
no aaa new-model
switch 1 provision ws-c2960x-24ps-l
ip routing
ip dhcp excluded-address 192.168.1.1 192.168.1.200
ip dhcp pool rich
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
lease 5
ip dhcp snooping vlan 3
ip dhcp snooping
crypto pki trustpoint TP-self-signed-4247657472
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-4247657472
revocation-check none
rsakeypair TP-self-signed-4247657472
spanning-tree mode rapid-pvst
vlan internal allocation policy ascending
interface FastEthernet0
no ip address
no ip route-cache
shutdown
interface GigabitEthernet1/0/1
switchport access vlan 3
switchport mode access
spanning-tree portfast edge
interface GigabitEthernet1/0/24
description uplink to modem
switchport access vlan 2
ip dhcp snooping trust
interface Vlan1
no ip address
shutdown
interface Vlan2
description wow
ip address dhcp
interface Vlan3
ip http server
ip http secure-server
line con 0
line vty 0 4
login
line vty 5 15
login
ntp server time-pnp.cisco.com
pnp profile pnp_cco_profile
transport https host devicehelper.cisco.com port 443
end
switch#
switch#sh ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override
Gateway of last resort is 52.6.218.1 to network 0.0.0.0
S* 0.0.0.0/0 [254/0] via 52.6.218.1
50.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 52.6.218.0/24 is directly connected, Vlan2
L 52.6.218.6/32 is directly connected, Vlan2
192.168.1.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.1.0/24 is directly connected, Vlan3
L 192.168.1.1/32 is directly connected, Vlan3
0 Replies 0
