05-07-2015
01:00 AM
- last edited on
03-25-2019
03:44 PM
by
ciscomoderator
Hello world,
I am trying to configure my Cisco 1921 Router at home with my cable modem connection using DHCP. I am using a Arris SB6183 DOCSIS 3.0 on Time Warner Cable in Los Angeles.
I've been trying to get this to work for the last couple of hours but no success so I'm desperate for help.
I can ping inside. Still can't ping out. sh ip int brief shows outside int UP and UP
Any help would be greatly appreciated... If you have any questions, please ask me!
Here's my sh run below
Dubai#sh run
Building configuration...
Current configuration : 1442 bytes
version 15.1
hostname Dubai
boot-start-marker
boot-end-marker
enable secret 5 $1$Podj$ytuWiSAK.mX69fQPRqUno1
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 192.168.10.201
ip dhcp excluded-address 192.168.10.202
ip dhcp excluded-address 192.168.10.203
ip dhcp excluded-address 192.168.10.204
ip dhcp excluded-address 192.168.10.205
ip dhcp pool home
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
lease 3
license udi pid CISCO1921/K9 sn **
interface GigabitEthernet0/0
ip dhcp client update dns
ip address dhcp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
no cdp enable
interface GigabitEthernet0/1
ip address 192.168.10.1 255.255.255.0
ip nat inside
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip nat inside source list 199 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
access-list 1 permit any
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
password *****
logging synchronous
login
transport input telnet ssh
scheduler allocate 20000 1000
end
05-07-2015 03:35 AM
pls provide outputs of below:
# sh ip int brie
# ping 4.2.2.2 sour gi0/0
05-07-2015 07:37 AM
I believe it's working now...
removing the default route fixed the issue?
07-23-2015 01:04 PM
This discussion has been reposted from Cisco On Demand to the WAN, Routing and Switching community.
05-07-2015 07:56 AM
Here is my new config.
sh ip int brief
Dubai#sh ip int brief
GigabitEthernet0/0 1*.*.*.* YES DHCP up up
GigabitEthernet0/1 192.168.10.1 YES NVRAM up up
NVI0 unassigned YES unset administratively down down
ping 4.2.2.2 source g0/0
Dubai#ping 8.8.4.4 source g0/0
Sending 5, 100-byte ICMP Echos to 8.8.4.4, timeout is 2 seconds:
Packet sent with a source address of 1.*.*.*
Success rate is 100 percent (5/5), round-trip min/avg/max = 8/9/12 ms
I've removed ip route 0.0.0.0 0.0.0.0 g0/0
and I noticed I was able to ping outside with the source of my outside int
and I hard coded the dns-servers
Here is my sh run
Current configuration : 1440 bytes
! Last configuration change at 08:49:58 UTC Thu May 7 2015
version 15.1
hostname Dubai
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip dhcp pool home
dns-server 209.18.47.61 209.18.47.62 8.8.4.4
lease 3
license udi pid CISCO1921/K9 sn *********
ip address dhcp
ip nat outside
duplex auto
speed auto
no cdp enable
ip nat inside
duplex auto
speed auto
no ip http server
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
password *****
logging synchronous
login
end
