cache empty on show ip flow
amralrazzaz
Level 5
Level 5
why cache is empty when i want to check who is the users consuming more bandwidth from internet connection ..why not showing ip addresses for users to monitor the netflow for each user on the interface that i configure already netflow??
Router#show ip flow top-talkers
% Cache is empty
amr alrazzaz
3 Accepted Solutions
Hello
You need to cef enabled either globally or interface for netflow to work.
res
Paul
Kind Regards
Paul
it will always be there once you save it , do wr or do copy run start
14 Replies 14
amralrazzaz
Level 5
Level 5
interface GigabitEthernet0/0
ip address 192.168.2.207 255.255.255.0
ip flow ingress
ip flow egress
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
no mop enabled
ip flow-export source GigabitEthernet0/0
ip flow-export version 9
ip flow-export destination 192.168.2.195 9996
ip flow-top-talkers
top 50
sort-by packets
amr alrazzaz
Amralrazzaz
What does the output of sh ip cef is telling you? Kindly consider copy/pasting the entire output of
term exec prompt timestamp
show int gig0/0
show ip interface gig0/0
Thanks ... Palani
Router#show ip interface g0/0
GigabitEthernet0/0 is up, line protocol is up
Internet address is 192.168.2.207/24
Broadcast address is 255.255.255.255
Address determined by non-volatile memory
MTU is 1500 bytes
Helper address is not set
Directed broadcast forwarding is disabled
Multicast reserved groups joined: 224.0.0.9
Outgoing access list is not set
Inbound access list is not set
Proxy ARP is enabled
Local Proxy ARP is disabled
Security level is default
Split horizon is enabled
ICMP redirects are always sent
ICMP unreachables are always sent
ICMP mask replies are never sent
IP fast switching is disabled
IP fast switching on the same interface is disabled
IP Flow switching is disabled
IP CEF switching is disabled
IP Null turbo vector
IP multicast fast switching is enabled
IP multicast distributed fast switching is disabled
IP route-cache flags are Fast
Router Discovery is disabled
IP output packet accounting is disabled
IP access violation accounting is disabled
TCP/IP header compression is disabled
RTP/IP header compression is disabled
Policy routing is disabled
Network address translation is enabled, interface in domain inside
BGP Policy Mapping is disabled
Input features: Common Flow Table, Stateful Inspection, Ingress-NetFlow, Virtual Fragment Reassembly, Virtual Fragment Reassembly After IPSec Decryption, MCI Check
Output features: NAT Inside, Common Flow Table, Stateful Inspection, NAT ALG proxy, Post-Ingress-NetFlow, Egress-Netflow
IPv4 WCCP Redirect outbound is disabled
IPv4 WCCP Redirect inbound is disabled
IPv4 WCCP Redirect exclude is disabled
Router#show int
Router#show interfaces g0/0
Hardware is CN Gigabit Ethernet, address is d46d.50bc.49f0 (bia d46d.50bc.49f0)
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full Duplex, 1Gbps, media type is RJ45
output flow-control is unsupported, input flow-control is unsupported
Last input 00:00:00, output 00:00:00, output hang never
Input queue: 0/75/0/62468 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 104000 bits/sec, 33 packets/sec
5 minute output rate 477000 bits/sec, 55 packets/sec
45138641 packets input, 2568207215 bytes, 0 no buffer
Received 451087 broadcasts (0 IP multicasts)
0 watchdog, 81090 multicast, 0 pause input
57646463 packets output, 3481233052 bytes, 0 underruns
63491 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
Router#
amr alrazzaz
amralrazzaz
Level 5
Level 5
here the full config
ip flow ingress
ip flow egress
ip nat inside
duplex auto
speed auto
no mop enabled
ip flow-top-talkers
top 50
sort-by packets
amr alrazzaz
right so you only need this config below for top talkers the rest is for export and its correct config
are you generating interesting traffic across g0 to be captured ? run an extended ping across that interface with G0 as the source and see if the cache fills
what device and software is this ?
ip flow-top-talkers
top 50
sort-by packets
ip flow ingress
ip flow egress
show version
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.4(3)M1, RELEASE SOFTWARE (fc1)
Cisco CISCO2911/K9 (revision 1.0) with 483328K/40960K bytes of memory.
483328K + 40960K = 524288kb (512MB)
255488K bytes of ATA System CompactFlash 0 (Read/Write)
255488K (256MB)
Cisco CISCO2911/K9
amr alrazzaz
did you generate traffic accroos that interface from source of it ?
i already made this configurations
but still empty cache
amr alrazzaz
Hello
res
Paul
Kind Regards
Paul
Router#show ip cef
%IPv4 CEF not running
Router#
can u please show me the configuration ????
thanks
amr alrazzaz
(config)#ip cef
yes its working thanks
but its not deleted i mean every time when i need to check the netflow i have to write this command or just write the command and do wr it will saved
amr alrazzaz
% Cache is empty
its deleted again and i cant catch the traffic for each user in network???
amr alrazzaz
