Cache Engine 510 - Replacing Hard drive
jgiarret
     I have a 510a Cache engine and the IDE hard drive failed.  I installed a new blank hard drive, but I can't get it to boot off of the new hard drive. Currently,  I moved the original to Disk 1.  I switched the boot up disk to disk 1.  I was then able to setup the new hard drive (in disk 0).  Everything is functioning, but I don't want to keep the dead hard drive in there.  How do I setup a boot sector on the new hard drive?
p.mcgowan
Level 3
Level 3
you need to partition the new disk
"disk config sysfs 5% cfs 45% mediafs from-unused cdnfs remaining"
This should partiton the disk
I already partitioned the drive 10% sysfs and 90% cfs.. which is what we've been using for years.  It still doesn't boot off of the new drive.  thanks for the repsonce.
have you loaded the ACNS software onto the new disk?
once you have partitioned the disk you must load on the CE software you were previously running;
confgure CE gig 1/0 with an IP address
"copy ftp install <ftp server ip address>
"show hardware will show is software is installed correctly
