Cache Enging 570
mounir.mohamed
Level 7
Level 7
Dear All,
Dear All,
Every time configuring the CE570 device then copy running startup then reload the device i found that the configuration restored to the old status and all new configurations lost i feel that the configuration file bypassed so anybody can advice:
mounir.mohamed
Level 7
Level 7
303949 bytes
copying bootagent
boot start: 0x17fee000
starting new system - entry 0x8010
Press any key to stop auto-boot...
auto-booting...
boot device (flash,net) [ flash]:
flags [ 0x4000]:
Starting at 0x108000...
#!ImageInfo
# | CISCO CE image |
SUPPORTED_PRODUCTS=CE570
UNCOMPRESSED_CKSUM=0xcdee44b8
UNCOMPRESSED_SIZE=0x362aa0
COMPRESSED_CKSUM=0xcf5d618c
COMPRESSED_SIZE=0x16d013
Self decompressing the image : ############################################################################################################# [OK]
Launching the image, please wait...
Console IO Initialized
Host Name: bootHost
User: admin
Attaching network interface lo0... done.
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
Cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco Cache Engine
Copyright (c) 1986-2001 by Cisco Systems, Inc.
Software Release: CE ver 2.51 (Build: FCS 05/24/01)
Compiled: 15:00:20 May 24 2001 by bbalagot
Image text-base 0x108000, data_base 0x4424module_register_init name sym func 0x1edda8 data 0x458f24
ccompat_pci_handler: sym probing...
895: found
sym0: No NVRAM, ID 7, Fast-40, LVD, parity checking
System restarted by Reload
The system has been up for 8 seconds.
System booted from "flash"
SVCINIT - phase complete
895: attached unit 0
Waiting 2 seconds for SCSI devices to settle
da0 at sym0 bus 0 target 0 lun 0
da0: Fixed Direct Access SCSI-3 device
da0: 80.000MB/s transfers (40.000MHz, offset 31, 16bit), Tagged Queueing Enabled
da0: 17510MB (35861388 512 byte sectors: 255H 63S/T 2232C)
da1 at sym0 bus 0 target 1 lun 0
da1: Fixed Direct Access SCSI-3 device
da1: 80.000MB/s transfers (40.000MHz, offset 31, 16bit), Tagged Queueing Enabled
da1: 17510MB (35861388 512 byte sectors: 255H 63S/T 2232C)
SCSI initialization complete
DEVINIT - phase complete
FSINIT - phase complete
Bypassing NVRAM Configuration...
"admin" super-user account is NOT password protected
SECURITY ALERT: Please password protect the above super-user accounts!
CONF - phase complete
get_our_ip_broadcast_address: ifMaskGet failed!
NTP: Waiting (2 minutes) for network initialization
SNMP: Waiting (2 minutes) for network initialization
Tue May 30 00:53:01 2006: * Warning *: No ip name-servers have been configured
http incoming proxy, http object url-validation and dns-cache
require an ip name-server
START - phase complete
cepro#lls
size date time name LongName
2552152 Feb-16-2001 14:18:00 CE570-~1.PAX ce570-220.pax
512 Feb-16-2001 14:18:02 ETC
etc
512 Feb-16-2001 14:18:02 LIB
lib
1386280 Feb-16-2001 14:18:10 CE570-~1.BIN ce570-220.bin
512 Feb-16-2001 14:58:34 TFTPBOOT
tftpboot
512 Feb-16-2001 14:58:34 VAR
var
0 Feb-11-2002 04:03:34 CE-570~1.PAX ce-570-cache-251.pax
2722321 Feb-11-2002 04:04:58 CE570-~2.PAX ce570-cache-251.pax
1508832 Feb-11-2002 04:05:14 CE570-~2.BIN ce570-251bcFCS.bin
4 DIR(S), 5 FILE(S) 8169585 bytes
1973682176 bytes AVAILABLE ON VOLUME /c0t0d0s1
cepro#lls /local/etc/boot
512 Feb-16-2001 14:18:02 .
512 Feb-16-2001 14:18:02 ..
512 May-30-2006 00:37:10 NVRAM
NVRAM
345 May-30-2006 00:44:02 CONFIG~1.TCL configure.tcl
3636 May-30-2006 00:44:04 CONFIG~2.TCL configure_local.tcl
357 May-30-2006 00:44:04 INIT.TCL init.tcl
249 May-30-2006 00:44:04 START.TCL start.tcl
3 DIR(S), 4 FILE(S) 4587 bytes
Best Reagrds,
Mounir Mohamed
