Can anyone help with an answer to the following NAT on IOS question.
byron.momsen
1)       On a Cisco router – Can two NATs be applied to the same traffic/packets? One NATing source to 172.17.3.5 and the other NATing destination to
ip nat inside source static 192.168.200.4 10.134.116.204
      and
ip nat pool MY-NAT-POOL 172.17.3.5 172.17.3.5 netmask 255.255.255.252
access-list 193 remark MY NAT - ACL
access-list 193 permit tcp 10.195.0.0 0.0.255.255 172.30.1.192 0.0.0.15
access-list 193 permit tcp 10.151.0.0 0.0.255.255 172.30.1.192 0.0.0.15
access-list 193 remark END
route-map MY-ROUTE-MAP permit 10
match ip address 193
ip nat outside source route-map MY-ROUTE-MAP pool MY-NAT-POOL route-add
interface GigabitEthernet0/0
ip nat inside
interface Serial0/0/0:13
ip nat outside
In other words for incoming traffic from outside to inside can you NAT the destination and the source?
I need to NAT the incoming source due to overlapping networks with this other network. The other network cannot change.
If you want to translate the source and the destination in the same packets them both nats must be statics.
Not completely true. See:
Using NAT in Overlapping Networks
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a0080093f30.shtml
6 Replies 6
byron.momsen
Correction:
1)   On a Cisco router – Can two NATs be applied to the same traffic/packets? One NATing source to 172.17.3.5 and the other NATing destination to 192.168.200.4.
      Objective of the config is: Orignal source 10.195.1.1 Original destination 10.134.116.204 - Translated source 172.17.3.5 Translated destination 192.168.200.4
      and
access-list 193 permit tcp 10.195.0.0 0.0.255.255 host 10.134.116.204
ip nat inside
ip nat outside
Never worked on something like this but I think following command implementation  can help you out :-
ip nat outside source list xx pool NAT add-route
please check out the following link for further information :-
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a0080093f8e.shtml
Manish
Hi Manish
Thanks for the link.
NAT command above only works if you only want to translate the source.
See my final solution below for nating the source and destination in the same packet. I have confirmed that this config works in a lab.
ip nat outside source static network 133.195.0.0 172.195.0.0 255.255.0.0 add-route
ip nat outside source static network 134.151.0.0 172.151.0.0 255.255.0.0 add-route
interface FastEthernet0/1.3
ip nat outside
exit
interface FastEthernet0/1.4
ip nat inside
exit
ip nat inside source static 10.10.16.204 10.36.74.133
Byron
Thanks Margalla
Thanks for the correction and info.
You are perfectly correct.
What I did find in my lab was that if the "ip nat inside" was a static and the "ip nat outside" used source route-map or source list
then  the static nat was applied to traffic and the ip nat outside did not work.
Looks like both must be static for both must be source list/route-map.
Thanks Margalla
typo: correction below. for should have been or
Looks like both must be static or both must be source list/route-map when translating ip nat outside "many to many"
