Can PPTP client, NAT and CEF work together?
aleks222
Brief background:
Simple network:
client -> Cisco 881 -> ISP
Bit more details:
client(192.168.0.12) -> Vlan1(192.168.0.3, ip nat inside) -> Dialer0(90.157.26.245, ip nat outside) -> {PPTP tunnel} -> ISP
With "ip cef" enabled, NAT does not work properly.NAT transmission of packets coming to the external interface is NOT happening.
With "no ip cef" NAT does work properly.
The question is how to fix it?
In other words, to make CEF, NAT and PPTP work together.
cisco.k259#sho run
Building configuration...
Current configuration : 8031 bytes
! Last configuration change at 20:02:03 GMT Fri Mar 15 2019 by atest
! NVRAM config last updated at 20:00:34 GMT Fri Mar 15 2019 by atest
version 15.4
no service pad
service internal
hostname cisco.k259
boot-start-marker
boot-end-marker
logging discriminator FAN-FAIL severity drops 3 facility drops FAN mnemonics drops FAN_FAILED
logging buffered discriminator FAN-FAIL
no logging console
logging monitor discriminator FAN-FAIL
enable secret 5 $1$WSti$mDMsh6sXY2iguEI/Mchiy1
enable password xxxxxxxx_
no aaa new-model
memory-size iomem 10
clock timezone GMT 5 0
crypto pki trustpoint TP-self-signed-3690135629
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-3690135629
 revocation-check none
 rsakeypair TP-self-signed-3690135629
crypto pki certificate chain TP-self-signed-3690135629
 certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
        quit
ip dhcp excluded-address 192.168.0.1 192.168.0.7
ip dhcp pool k259
 import all
 network 192.168.0.0 255.255.255.0
 default-router 192.168.0.1
 domain-name k259
 dns-server 192.168.0.12 8.8.8.8
 lease 0 2
ip domain name k259
ip name-server 192.168.0.12
ip name-server 8.8.8.8
ip inspect WAAS flush-timeout 10
no ip cef
no ipv6 cef
vpdn enable
vpdn-group PPTP_CLIENT
 description Rostelecom ISP
 request-dialin
  protocol pptp
  pool-member 1
 initiate-to ip 10.0.0.1
cts logging verbose
license udi pid CISCO881W-GN-E-K9 sn FCZ164190LZ
username atest privilege 15 secret 4 6in4Lru2ZZ8N8cUij4q7JvPlkL..hsURCkjm.d4NOR2
no cdp run
interface FastEthernet0
 no ip address
interface FastEthernet1
 no ip address
interface FastEthernet2
 no ip address
interface FastEthernet3
 no ip address
interface FastEthernet4
 ip address 10.0.47.132 255.255.255.0
 ip flow ingress
 ip flow egress
 duplex auto
 speed auto
interface wlan-ap0
 description Service module interface to manage the embedded AP
 ip address 10.10.11.1 255.255.255.0
 arp timeout 0
interface Wlan-GigabitEthernet0
 description Internal switch interface connecting to the embedded AP
 no ip address
interface Vlan1
 description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
 ip address 192.168.0.5 255.255.255.0 secondary
 ip address 192.168.0.3 255.255.255.0
 ip flow ingress
 ip flow egress
 ip nat inside
 ip virtual-reassembly in
 ip tcp adjust-mss 1452
interface Dialer0
 description $ETH-WAN$
 mtu 1450
 ip address negotiated
 ip flow ingress
 ip flow egress
 ip nat outside
 encapsulation ppp
 ip tcp adjust-mss 1410
 shutdown
 dialer pool 1
 dialer idle-timeout 0
 dialer string 123
 dialer persistent
 dialer vpdn
 ppp authentication ms-chap-v2 callin
 ppp chap hostname 90.157.26.245
 ppp chap password 0 xxxxxxxxx
 no cdp enable
ip forward-protocol nd
ip http server
ip http access-class 23
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:
no ip ftp passive
ip dns server
ip nat translation max-entries all-host 400
ip nat inside source static tcp 192.168.0.12 3389 interface Dialer0 3389
ip nat inside source list 1 interface Dialer0 overload
ip nat inside source list 101 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0 3
ip route 10.0.0.1 255.255.255.255 10.0.47.1
ip route 10.10.11.0 255.255.255.0 wlan-ap0
dialer-list 1 protocol ip permit
snmp-server community k259 RO
access-list 1 remark internet
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.0.0 0.0.0.255
access-list 23 remark CCP_ACL Category=17
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 23 permit 192.168.0.0 0.0.0.15
access-list 101 remark internet2
access-list 101 remark CCP_ACL Category=2
access-list 101 remark test 2
access-list 101 permit ip 192.168.0.0 0.0.0.255 any
 vstack
banner exec ^C
% Password expiration warning.
^C
banner login ^C
Cisco Configuration Professional (Cisco CP) is installed on this device.
^C
line con 0
 login local
 no modem enable
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
line vty 0 4
 access-class 23 in
 privilege level 15
 password xxxxxxxx
 login local
 transport input telnet ssh
ntp master
ntp update-calendar
ntp server ntp2.stratum2.ru
end
0 Replies 0
