Can't access the share folder from VPN branch office
junaid haroon
We have headoffice and branch office.both are connected through VPN.From headoffice i want to access the share folder of branch office (\\ipaddress of share folder).Its give me the error no logon server available or your are not authorized.where as from branch office i can access the share folder of head office.
following is the configuration of my branch office router pls help me out.
urrent configuration : 3517 bytes
version 12.4
hostname KHhhI_RTR
boot-start-marker
boot-end-marker
logging message-counter syslog
enable password ***************************
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ip domain lookup
ip name-server 202.163.96.3
ip name-server 202.163.96.4
no ipv6 cef
voice-card 0
archive
log config
  hidekeys
crypto isakmp policy 10
hash md5
authentication pre-share
group 2
crypto isakmp key *********************** address 124.109.46.242
crypto ipsec transform-set tset esp-des esp-md5-hmac
crypto map smap 10 ipsec-isakmp
set peer 124.109.46.242
set transform-set tset
match address 101
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.1.254 255.255.255.0
no shutdown
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
duplex auto
speed auto
interface ATM0/2/0
no shutdown
no ip address
no atm ilmi-keepalive
pvc 0/35
pppoe-client dial-pool-number 1
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username ************ password 0 ******
crypto map smap
no shutdown
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
no ip http secure-server
ip nat inside source list 111 interface Dialer1 overload
access-list 101 permit ip 192.168.1.0 0.0.0.255 host 124.109.46.245
access-list 101 permit ip 192.168.1.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
access-list 111 deny   ip 192.168.1.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 111 permit ip 192.168.1.0 0.0.0.255 any
dialer-list 1 protocol ip permit
route-map nat permit 10
match ip address 102
snmp-server community makkays RO
snmp-server community public RO
snmp-server enable traps tty
control-plane
mgcp fax t38 ecm
line con 0
line aux 0
line vty 0 4
scheduler allocate 20000 1000
time-range open-hours
end
Ok, then check firewall on that machine. If the folder is shared. Seems VPN connection works fine. What about device on Branch office is there any ACL or firewall turned on. If it doesn't work show config from branch router/firewall.
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
9 Replies 9
Abzal
Level 7
Level 7
Fix this crypto ACL:
no access-list 101 permit ip 192.168.1.0 0.0.0.255 any
And if there are any other subnet in Branch office you need to add them to crypto ACL as well. And deny them in ACL #111.
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
I did the same ACL as you said but still facing a issue
Then show your current fixed config. Can you ping that server from Head office?
Show some output:
show crypto ipsec sa
show crypto session
show crypto session detail
debug crypto ipsec
debug crypto isakmp
Then try to establish a connection.
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
Yea Abzal
I can ping,take the remote destop of any pc of branch office fron our headoffice.But problem come when i try to access the share
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
Yes i checked the Firewall it is turn off.
Following is the configuration of branch router
version 12.4
hostname KHhhI_RTR
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
voice-card 0
archive
log config
  hidekeys
hash md5
group 2
match address 101
no ip address
shutdown
duplex auto
speed auto
no shutdown
ip nat inside
duplex auto
speed auto
interface ATM0/2/0
no shutdown
no ip address
pvc 0/35
interface Dialer1
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
crypto map smap
no shutdown
ip http server
control-plane
mgcp fax t38 ecm
line con 0
line aux 0
line vty 0 4
end
Is your problem solved? If not then show config of Head office.
Try this from any PC in head office:
telnet 445
server_from_brach - IP address of PC from branch that you cannot access shared folder.
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
No Not resolved.
Sorry Actually i accidently click on the Coreect answer TAB.Abzal i don't think the problem is Headoffice firewall bez all other branch offices VPN are terminated on PIX firewall at Headoffice.(Hub spoke VPN).All other branches are working fine.
when i telnet this it give me
not connected message
I think the problem is on that PC from branch.
What if you:
1. try to open the shared folder that you're having problem with from any branch PC.
2. try to open the folder from any other head office's PC(from different PCs).
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
