Can't get through ASA 5505
John.Carson.75
Hi, I'm sorry to ask, but have been battling with this for days now.  I've been tasked with setting up an ASA 5505 on our ADSL modem & am very lost.  I've put the PPPoE details into the ASA 5505 to authenticate with our ISP, but can't get out through it.  I've looked at guides, videos, compared configs, but can't see where I'm going wrong.  Can someone help please, I know it's supposed to be secure, but not quite this secure.  I'm going crazy!
This is the current config...
: Saved
ASA Version 8.2(5)
hostname asa
enable password GuuH2OTIRWlZP8z3 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
pppoe client vpdn group ADSL
ip address pppoe setroute
ftp mode passive
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1492
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat-control
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh timeout 5
console timeout 0
vpdn group ADSL request dialout pppoe
vpdn group ADSL localname zen218339@zen
vpdn group ADSL ppp authentication chap
vpdn username zen218339@zen password ***** store-local
dhcpd auto_config outside
dhcpd address 192.168.1.5-192.168.1.36 inside
dhcpd auto_config outside interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
webvpn
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:de68420cce338ff3b60f7b5ca5c35ce8
: end
Thanks.
John Blakley
John,
Your config looks fine to me. There are a couple of things that you'll need to do with your policy map. First of all, from the ASA, can you ping 4.2.2.1 successfully? If not, do a "vpdn session pppoe state" to see if your session is up. If you aren't up, the something is going on between the ASA and the provider. You could try changing the authentication to pap, because believe it or not there are still some providers out there that still use it.
Otherwise, if you CAN ping 4.2.2.1 successfully, then add the following:
inspect http
inspect icmp
See if that will get you out.
** Edit **
Make sure that you have a DNS server assigned to your clients as well:
dhcpd dns
HTH,
John
Please rate useful posts...
HTH, John *** Please rate all useful posts ***
rizwanr74
Level 7
Level 7
Hi John,
Please try this.
show route
and look for an output as shown below.
Gateway of last resort is 64.230.200.143 to network 0.0.0.0
In my case, my default-gateway happen to be at 64.230.200.143
If you still have the issue, then.
config just like I have on my ASA shown below and I do not have an SVI (vlan) interface for outside but rather, I go directly on the interface itself.
interface Ethernet0
nameif outside
security-level 0
pppoe client vpdn group bellnet
vpdn group bellnet request dialout pppoe
vpdn group bellnet localname b1nkbaxx
vpdn group bellnet ppp authentication pap
vpdn username b1nkbaxx password ********* store-local
dhcpd dns 207.164.234.193 207.164.234.129
Let me know, if this helps.
thanks
Rizwan Rafeek
