Can't Ping
brianc0710
Although my ISP Router s0/0/0 can ping to CustRouter s0/0/0, but it cannot ping to the other port of  CustRouter, make it also cannot connect to the right side of the network.
 An packetracer file is attached for you to review
Thank you
M02@rt37
Hello @brianc0710
ISP Router doesn't have any routes to communicate with others IP attached to CustRouter:
As an example, add static route to ISP Router to joing 10.25.200.128/30 attached to CustRouter:
=> Ping succesfull
Best regards
M02@rt37
Hello @brianc0710
=> Ping succesfull
Best regards
Thanks for your solution!
You're very welcome @brianc0710
Best regards
