01-11-2013 07:12 PM - edited 03-04-2019 06:41 PM
Hi All,
I'm a new MPLS learner and i've been trying to test a MPLS VPN in GNS3. Everything is working fine except i can't see MPLS label in traceroute result from CE to CE. However i'm able to see MPLS label when i do traceroute from PE to PE and from P to P. Could someone advise what is the possible issue with this? Below are traceroute results:
************ From CE to CE **************** NO Label found *****************
CE-R7#trac 20.20.20.1
Tracing the route to 20.20.20.1
1 172.16.1.1 84 msec 120 msec 24 msec
2 10.1.1.2 200 msec 236 msec 360 msec
3 10.1.3.3 176 msec 304 msec 208 msec
4 172.16.2.1 264 msec 192 msec 228 msec
5 172.16.2.2 232 msec * 224 msec
********** From PE to PE ************** Can see the label******************
PE-R1#trac 6.6.6.6
Tracing the route to 6.6.6.6
1 10.1.2.2 [MPLS: Label 23 Exp 0] 216 msec
10.1.1.2 [MPLS: Label 19 Exp 0] 140 msec
10.1.2.2 [MPLS: Label 23 Exp 0] 100 msec
2 10.1.3.3 [MPLS: Label 17 Exp 0] 144 msec
10.1.3.4 [MPLS: Label 23 Exp 0] 68 msec
10.1.3.3 [MPLS: Label 17 Exp 0] 320 msec
3 10.1.5.2 120 msec
10.1.4.2 160 msec *
Appeciate for any reply.
Vannara,
01-11-2013 07:46 PM
If you have "no mpls ip propagate-ttl" your traceroutes will not show the label on the ce routers. Is this enabled?
01-13-2013 07:35 PM
Hi John, Thanks for your reply.
This command hasn't been enabled on all PE & P routers. However, as mentioned in my prevoius message, i'm able to see MPLS label in my traceroute from PE to PE but not from CE to CE. Is there any further suggestion/recommendation?
Vannara
01-14-2013 12:19 AM
Hello ,
I think , you're seeing normal behavior of MPLS Network , the label will be pop at PE edge : because packet at CE is IP packet not labeled packet : when LSR receive labeled packet it strip off label and send it as IP packet to CE router.
01-14-2013 05:29 PM
Hi Adnane, I think so, however based on the lab (link below) from which i've practiced, i can see their traceroute result from CE to CE having MPLS label. Not sure why it does.
http://packetlife.net/blog/2011/may/16/creating-mpls-vpn/
CE1A# traceroute 172.16.0.2 Type escape sequence to abort. Tracing the route to 172.16.0.2 1 10.0.1.1 4 msec 4 msec 8 msec 2 10.0.9.5 [MPLS: Labels 19/22 Exp 0] 16 msec 12 msec 24 msec 3 10.0.9.2 [MPLS: Labels 19/22 Exp 0] 24 msec 20 msec 16 msec 4 10.0.2.1 [MPLS: Label 22 Exp 0] 20 msec 16 msec 24 msec 5 10.0.2.2 16 msec * 36 msec
Thanks all for your reply.
01-14-2013 06:57 PM
Technically, you only need it enabled on the PEs to hide the labels from the CEs end-to-end...
HTH,
John
*** Please rate all useful posts ***
01-15-2013 02:16 AM
John, I wish MPLS label also displayed from CE to CE traceroute. Any idea how to make it?
B Regards,
Vannara
01-15-2013 03:28 AM
Can you post your config of the PEs and a diagram? Also, this depends on what IOS you're using. I remember when I was labbing this up, I couldn't get the labels to go away until I updated the IOS. So you could have the opposite problem. If I have the same IOS version that you have, I could lab it up and see what I come up with...
HTH,
John
01-15-2013 05:51 AM
Hi John, here is IOS version i'm using,
P-R2#show version
Cisco IOS Software, 3700 Software (C3725-ADVENTERPRISEK9-M), Version 12.4(12), RELEASE SOFTWARE (fc1)
******* PE1******************
version 12.4
hostname PE-R1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
ip vrf Customer_A
rd 120:120
route-target export 20:20
route-target import 30:30
no ip domain lookup
ip domain name lab.local
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface FastEthernet0/0
ip address 10.1.1.1 255.255.255.252
duplex auto
speed auto
mpls ip
interface FastEthernet0/1
ip address 10.1.2.1 255.255.255.252
duplex auto
speed auto
mpls ip
interface FastEthernet1/0
ip vrf forwarding Customer_A
ip address 172.16.1.1 255.255.255.252
ip ospf 2 area 0
duplex auto
speed auto
router ospf 2 vrf Customer_A
router-id 172.16.1.1
log-adjacency-changes
redistribute bgp 6500 subnets
router ospf 1
redistribute connected metric-type 1 subnets
redistribute static
passive-interface default
no passive-interface FastEthernet0/0
no passive-interface FastEthernet0/1
network 10.1.1.1 0.0.0.0 area 0
network 10.1.2.1 0.0.0.0 area 0
router bgp 6500
no synchronization
bgp log-neighbor-changes
neighbor 6.6.6.6 remote-as 6500
neighbor 6.6.6.6 update-source Loopback0
no auto-summary
address-family vpnv4
neighbor 6.6.6.6 activate
neighbor 6.6.6.6 send-community extended
exit-address-family
address-family ipv4 vrf Customer_A
redistribute connected metric 1
redistribute ospf 2 vrf Customer_A
no synchronization
exit-address-family
no ip http server
no ip http secure-server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
************* CE1 *******************
version 12.4
hostname CE-R7
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
interface Loopback0
ip address 192.168.1.1 255.255.255.255
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
ip address 172.16.1.2 255.255.255.252
duplex auto
speed auto
router ospf 1
no passive-interface FastEthernet1/0
no passive-interface Loopback0
network 172.16.1.2 0.0.0.0 area 0
network 192.168.1.1 0.0.0.0 area 0
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
***************** PE2 ************************************
version 12.4
hostname PE-R6
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
ip vrf Customer_A
rd 120:120
route-target export 30:30
route-target import 20:20
no ip domain lookup
interface Loopback0
ip address 6.6.6.6 255.255.255.255
ip address 10.1.4.2 255.255.255.252
duplex auto
speed auto
mpls ip
ip address 10.1.5.2 255.255.255.252
duplex auto
speed auto
mpls ip
ip address 172.16.2.1 255.255.255.252
ip ospf 2 area 0
duplex auto
speed auto
router-id 172.16.2.1
router ospf 1
redistribute static
network 10.1.4.2 0.0.0.0 area 0
network 10.1.5.2 0.0.0.0 area 0
router bgp 6500
no synchronization
neighbor 1.1.1.1 remote-as 6500
neighbor 1.1.1.1 update-source Loopback0
no auto-summary
neighbor 1.1.1.1 activate
neighbor 1.1.1.1 send-community extended
exit-address-family
no synchronization
exit-address-family
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
******************CE2 *********************
version 12.4
hostname CE2-R8
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
interface Loopback0
ip address 20.20.20.1 255.255.255.255
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
ip address 172.16.2.2 255.255.255.252
duplex auto
speed auto
router ospf 1
network 20.20.20.1 0.0.0.0 area 0
network 172.16.2.2 0.0.0.0 area 0
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
01-15-2013 06:28 AM
Xei Yao, according to document and if i'm not confused, it is not recommended to enable MPLS interface toward customer's equipments. MPLS are only to ne enabled on interface pointing to core network. That is why didn't do that.
01-15-2013 07:57 AM
It very well could be a bug...I have 12.4(15)T14 and it seems to work fine:
R1#traceroute 172.45.0.5
Tracing the route to 172.45.0.5
1 172.12.0.2 32 msec 16 msec 4 msec
2 10.23.0.3 [MPLS: Labels 16/20 Exp 0] 64 msec 60 msec 68 msec
3 172.45.0.4 80 msec 60 msec 56 msec
4 172.45.0.5 92 msec * 84 msec
HTH,
John
01-16-2013 12:14 AM
Hi John/All,
Thanks for all your advice. Finally i'm able to see MPLS label after upgradeing IOS in CE routers.
Version 12.4(24)T, RELEASE SOFTWARE (fc1)
CE1#trac 172.16.1.1
Tracing the route to 172.16.1.1
1 10.1.1.2 92 msec 132 msec 28 msec
2 60.1.1.2 [MPLS: Labels 18/24 Exp 0] 108 msec 96 msec 152 msec
3 20.1.1.2 [MPLS: Label 24 Exp 0] 136 msec 112 msec *
4 20.1.1.1 140 msec * 280 msec
Again, appreciated all your support.
01-15-2013 05:33 AM
I am not sure whether this is a IOS bug or not, but I do remember that if you enable mpls under the interface of CE router, you should be able to see the label, try that.
Yao Xie
03-30-2023 01:07 PM
yes, this is true, i was unable to see mpls labels in the cli traceroute output* on the CE, but I can now with enabling "mpls ip" on an interface of that CE router. I recall learning this a year ago, and had to learn it all over again today! interestingly, you don't even have to do it on the WAN interface where the traceroute replies enter, you can even use the LAN interface if you wish. i guess a bug, look others have said.
using IOS in EVE-NG for a 3735 node...
R1#traceroute 10.10.12.2 probe 1 numeric
Tracing the route to 10.10.12.2
1 10.10.1.1 24 msec
2 10.10.10.1 112 msec
3 10.10.10.6 92 msec
4 10.10.10.10 60 msec
5 10.10.11.2 92 msec
6 10.10.12.2 80 msec
R1#
R1#conf t
Enter configuration commands, one per line. End with CNTL/Z.
R1(config)#int f0/0
R1(config-if)#mpls ip
R1(config-if)#^Z
R1#
1 10.10.1.1 16 msec
2 10.10.10.1 [MPLS: Label 23 Exp 0] 68 msec
3 10.10.10.6 [MPLS: Label 23 Exp 0] 72 msec
4 10.10.10.10 [MPLS: Label 20 Exp 0] 52 msec
5 10.10.11.2 48 msec
6 10.10.12.2 72 msec
R1#
R1#sh ver | in IOS
Cisco IOS Software, 3700 Software (C3725-ADVENTERPRISEK9-M), Version 12.4(9)T7, RELEASE SOFTWARE (fc3)
R1#
also, i think this is based on RFC 4884 and/or 4950, ICMP Multi-Part Extensions
03-30-2023 02:56 PM - edited 03-30-2023 03:06 PM
Hi @a-gould ,
It appears that the traceroute would not display the labels unless the local mpls component was enabled (i.e. "mpls ip" on any interface). This is not a restriction anymore with more recent ios versions.
