Can we do load balancing over two VPN links?
alanchia2000
I have two VPN links which I wish to do "per connection" load balancing? Is this even possible?
If so, how can it be done?
______________________VPN link 1 _____
SW -----------LINUX box--------
|_____________________VPN link 2 ______
Would appreciate it if anyone could help?
spremkumar
Level 9
Level 9
AFAIU from ur post ur Switch is the agg point for both ur LAN and WAN.
U linux box is connected to ur switch and ur local domain comes behind ur linux box ..
do correct if i hv messed up abt ur setup somewhere...
do pen about ur Switch model details , the kinda VPN as well as WAN connectivity details between ur locations and also any routing protocols being used between ur locations @ present..
regds
The linux machine is in the Internal network, and the end of the VPN connection is an Internet connection performing NAT. As for the switch model, it is a Catalyst 3550. Currently, no protocols run on any switch on.
----linux box ---- sw 3550 ---- linux box --- vpn --- nat ---
