carl_townshend
Frequent Contributor
can you extand a vlan over 2 sites using routers, over a serial or frame relay circuit etc
Hi all
Is it possible to extend a vlan between 2 sites using routers, via serial, Ethernet or frame relay, its none mpls so eompls is not possible
cheers
Carl
2 REPLIES 2
johnd2310
Collaborator
Why do you need to extend the vlan? Why not route between the 2 sites.
John
**Please rate posts you find helpful**
Yes, it's possible. It can be archived with l2tp or otv, depends on  router hardware platform.
Minh
