Cannot access DNS/Internet from 1921
murtuzakazmi
Hello Experts,
I have been playing around with a 1921/K9 router in our dev environment. It's been about 24 hours and I just can't seem to get it to work. My DHCP Server is working hence my internal network is getting IP address as desired. But Router doesn't seem to connect to internet for some reason.
I am trying to make it a internet facing router with static IP address (67.210.209.113). LAN side of this router will be our .11 Network which is our Dev Network.
Here is some network information:
WAN:
Interface IP: 67.210.111.111
Default Gateway: 67.210.111.222 (I can ping this address through router)
tlm1921A-11A#ping 67.210.111.222
Sending 5, 100-byte ICMP Echos to 67.210.111.222, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
LAN:
Interface IP: 192.168.11.1
Network: 192.168.11.0/24
I cannot ping google.com OR 8.8.8.8 from the router
I am connected to the router through COM as well as CPP.
If any one of you can help me out - I would really really appreciate it.
King regards,
Murtuza
Here is my run file. Some settings might be a little messed up as I have been trying different guides and methods to get this up and running !!
hostname tlm1921A-11A
boot-start-marker
boot-end-marker
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
clock timezone PCTime -5 0
clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00
no ipv6 cef
ip source-route
no ip routing
no ip cef
ip dhcp excluded-address 192.168.11.1 192.168.11.184
ip dhcp excluded-address 192.168.11.206 192.168.11.254
ip dhcp pool 11Network
import all
network 192.168.11.0 255.255.255.0
dns-server 8.8.8.8 4.2.2.2
default-router 192.168.11.1
ip name-server 8.8.8.8
ip name-server 4.2.2.2
interface Embedded-Service-Engine0/0
no ip address
no ip route-cache
shutdown
interface GigabitEthernet0/0
description 11WAN$ETH-WAN$
ip address 67.210.111.111 255.255.255.224
ip nat outside
ip virtual-reassembly in
no ip route-cache
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
description 11LAN
ip nat inside
ip address 192.168.11.1 255.255.255.0
no ip route-cache
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat pool Pool 10.10.10.1 10.10.10.10 netmask 255.255.255.0
ip route 0.0.0.0 0.0.0.0 67.210.111.222
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.11.0 0.0.0.255
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password tlmcisco
transport input telnet ssh
transport output telnet ssh
line vty 5 15
scheduler allocate 20000 1000
end
7 Replies 7
liam onions
Try changing dns server too 192.168.11.1.
But I can't even reach 8.8.8.8 from the router itself - perhaps it's not finding the right route to go to my Default Gateway 67.210.111.222. Thoughts?
You think changing dns server to a LAN Interface would fix the issue?
yeah should be ok once you resolve dns locally.
what switch you using ?
to be able to ping internet addresses from the router: enter this command in global config mode   ip routing
to do the same from LAN: ip nat inside source list 1  interface g0/0
Regards.
Alain
Elton Babcock
I don't see where you have defined your NAT statement such as:
IP NAT inside source list 1 interface gigabitethernet overload
Hello Murtuza,
A few things -
1) do you really have a allocation of 32 public addreses?
2) your public assigned ip address isnt NOT in the same subnet range has the gateway you have stated
3 your nat pool isnt in the same range as the isp range
4) misssing nat statement to bind the nat pool with acl  1 and inside nat
to test connectivity before applying nat etc  , can you try-
1)removing nat statement from gig0/0
2)enable ip routing
3)add a default static route towards your ISP router lan ip address ( whatever this is)
4)try sourcing the icmp test from a specified interface of G0/0
res
Paul
Kind Regards
Paul
