01-27-2020 06:24 AM - edited 01-27-2020 11:46 AM
hi, can you help me, how to access Server-A from WAN. I have 3 devices:
- firewall (sonicwall)
- router (Cisco)
- Switch (Cisco)
with the topology as shown below:
as default initially installs the Sonicwall firewall, the x0 and x1 interfaces are activated. x0 as a LAN interface and x1 as a WAN interface.
interface x0 connects to the router interface gi0 / 0 and gets the ip address 192.168.168.65 as dhcp from the firewall device.
to drive traffic to Server-A, on my firewall device I create NAT policies and Access rules, as shown below:
192.168.168.65 -------------> referred to as "Web Server" NAT Policy Settings ==================== Original Source : Any Translated Source : Original Original Destination : WAN Interface IP Translated Destination : Web Server Original Service : HTTP Translated Service : Original Inbound Interface : X1 Outbound Interface : Any Access Rules ============ From : WAN To : LAN Source Port : HTTP Service : HTTP Source : Any Destination : WAN Interface IP Users Included : All Users Excluded : None Schedule : Always On
also on cisco router devices, I made a NAT policy:
! ip nat inside source static tcp 172.16.10.10 443 interface gi0/0 80 ! ip access-list standard NAT permit 172.16.10.0 0.0.0.255 ! ip nat inside source list NAT interface GigabitEthernet0/0 overload !
using the settings above, on LAN I can access Server-A. Server-A can also access the internet.
but when I try to access Server-A from WAN, the connection is refused.
Thank you in advance
Solved! Go to Solution.
01-28-2020 12:52 AM - edited 01-28-2020 12:53 AM
So Do you have on Sonicwall Firewall for this IP
36.255.220.93
if anyone accessing from outside, do you have NAT and Access-list allowed the connection in?
you need put the config in place to work.
1. Sonicwall required to allow from outside connection NAT and ACL ( and forwarding to router)
2. The router should have an ACL and forward table to server.
https://www.cisco.com/c/en/us/support/docs/ip/network-address-translation-nat/13772-12.html
01-27-2020 06:47 AM
Do you have enough policy ACL available from your Soniwall to allow traffc in ?
can you post full config of router to look your NAT and ACL.
01-27-2020 11:36 AM
thank you for responding, "show run" my router:
Building configuration... Current configuration : 3025 bytes cwmp ! vlan 1 ! vlan 10 name VLAN-MGMT ! vlan 16 name VLAN_DMZ ! vlan 20 name VLAN-WIFI ! ! no service password-encryption service dhcp ! ip dhcp excluded-address 192.168.10.1 192.168.10.9 ip dhcp excluded-address 192.168.20.1 192.168.20.9 ip dhcp excluded-address 172.16.10.1 172.16.10.9 ! ! ip dhcp pool User_Pool network 192.168.10.0 255.255.255.0 dns-server 8.8.8.8 default-router 192.168.10.1 ! ip dhcp pool User_Pool_20 network 192.168.20.0 255.255.255.0 dns-server 8.8.8.8 default-router 192.168.20.1 ! ip dhcp pool DMZ_Pool network 172.16.10.0 255.255.255.0 dns-server 8.8.8.8 default-router 172.16.10.1 ! control-plane ! control-plane protocol acpp bw-rate 1250 bw-burst-rate 2500 ! control-plane manage port-filter arp-car 5 acpp bw-rate 1250 bw-burst-rate 2500 ! control-plane data glean-car 5 acpp bw-rate 1250 bw-burst-rate 2500 ! enable secret 5 $1$mniP$pC9F4FzyuA3Dxyvx enable service web-server http enable service web-server https ! interface GigabitEthernet 0/0 ip nat outside ip address dhcp duplex auto speed auto ! interface GigabitEthernet 0/1 duplex auto speed auto ! interface GigabitEthernet 0/2 duplex auto speed auto ! interface GigabitEthernet 0/3 duplex auto speed auto ! interface GigabitEthernet 1/0 ! interface GigabitEthernet 1/1 switchport mode trunk ! interface GigabitEthernet 1/2 ! interface GigabitEthernet 1/3 ! interface GigabitEthernet 1/4 ! interface GigabitEthernet 1/5 ! interface GigabitEthernet 1/6 ! interface GigabitEthernet 1/7 ! interface GigabitEthernet 1/8 ! interface GigabitEthernet 1/9 ! interface GigabitEthernet 1/10 ! interface GigabitEthernet 1/11 ! interface GigabitEthernet 1/12 ! interface GigabitEthernet 1/13 ! interface GigabitEthernet 1/14 ! interface GigabitEthernet 1/15 ! interface GigabitEthernet 1/16 ! interface GigabitEthernet 1/17 ! interface GigabitEthernet 1/18 ! interface GigabitEthernet 1/19 ! interface GigabitEthernet 1/20 ! interface GigabitEthernet 1/21 ! interface GigabitEthernet 1/22 ! interface GigabitEthernet 1/23 ! interface VLAN 1 ip address 192.168.1.1 255.255.255.0 ! interface VLAN 10 ip nat inside ip address 192.168.10.1 255.255.255.0 ! interface VLAN 16 ip nat inside ip address 172.16.10.1 255.255.255.0 ! interface VLAN 20 ip nat inside ip address 192.168.20.1 255.255.255.0 ! ! ip route 0.0.0.0 0.0.0.0 10.1.1.1 ! end
01-27-2020 07:16 AM
what IP address are you using to connect from the WAN (I assume with WAN you mean the Internet) to Server-A ?
01-27-2020 11:41 AM - edited 01-27-2020 11:44 AM
as inbound, i use ip address 192.168.168.65 on the router interface gi0/0.
01-27-2020 12:39 PM
192.168.168.65 is a private space address, from where are you trying to access this address ? What is the WAN ? Is the WAN the Internet ?
I suggest you add the IP addresses to your drawing so we can see how you want to access the server, and from where.
01-27-2020 01:45 PM - edited 01-27-2020 01:53 PM
Firewall devices have 2 interfaces, x0 as a LAN interface and x1 as a WAN interface.
interface x0 is connected to the router interface gi0/0 and gets the ip address 192.168.168.65 from the firewall device.
thank you.
01-27-2020 05:25 PM
adding to another post as your drawing not show any IP address, we understand the router has 192.x ip address, But from the internet what IP address you trying to connect (hope your WAN definition is from the internet ?)
so the NAT needs to take place from Sonicwall, Router - then Server.
01-27-2020 07:41 PM - edited 01-27-2020 07:44 PM
I want to access the web server on port 443/80 and redirect to the internal (private) server ip address on port 443, for example:
if in the browser I access the ip address https://36.255.220.93 directed to server
computer 172.16.10.12 on port 443. that's it.
thank you
36.255.220.93
01-29-2020 03:16 AM
Thank you, I will try your advice. I will return with the results.
01-29-2020 12:35 PM
Hi, using my settings above, on the firewall device, I made a nat policy using the private use ip translation 192.168.168.65 (router ip address, get from the firewall device) And now I can access the web server from WAN / LAN.
Thank you guys for your help
