Cannot Access Public IP Server from Inside
iniguschannel
So, I have local server grafana that being nat to public ip, it can be accessed if I access from external network. Here I want to access my public grafana server from inside/internal network. Here is the example we say :
Local server grafana ip 192.168.10.70
Public ip that being nat to grafana local 201.10.10.100
here's the config:
object network IP_Local_Grafana
host 192.168.10.70
object network Local-IP_Grafana
host 192.168.10.70
object network Public-IP_Grafana
host 201.10.10.100
nat (inside,outside) static Public-IP_Grafana
nat (inside,inside) static Public-IP_Grafana
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object-group service DM_INLINE_SERVICE_1
service-object icmp
service-object icmp echo-reply
service-object tcp destination eq ftp
service-object tcp destination eq www
service-object tcp destination eq 3000
access-list outside_access_in extended permit object-group DM_INLINE_SERVICE_1 any object Local-IP_Grafana
I still cannot access my grafana's public ip, what's wrong? Please someone help I really appreciate.
11 Replies 11
Yes sir, from that pic LAN cannot access Public's ip server. I want to local network can access to public ip that being nat into my local grafana server. Is there no solution?
change the NAT from objec to manual nat
nat (inside,outside) static Public-IP_Grafana <<- remove this
nat (inside,inside) static Public-IP_Grafana <<0 remove this
add this
nat(INSIDE,OUTSIDE) .....
nat(INSIDE, INSIDE).....
Oke sir I will try and inform if solved thank you
 Why you want to access to the public or NATted IP address? Why not on the real ip address? Is there a reason?
Because that Public IP resolved to my domain and I want to access through my domain sir. Is there any solution sir?
Do you have internal DNS or is it external?
Yes I have Internal DNS sir
Have you considered create an entry for the graphana server resolving internally and then use "no-nat" feature when the traffic were from inside to graphana interface?
object network inside
host x.x.x.x
host 192.168.10.70
nat (inside,IP_Local_Grafana) source static inside inside destination static IP_Local_Grafana IP_Local_Grafana
Isn't this config wrong sir?
ASA(config-network-object)# nat (inside,Local-IP_Grafana) source ?
ERROR: % Unrecognized command
Current available interface(s):
any                      Global address space
inside                  Name of interface Ethernet1/2
management     Name of interface Management1/1
outside               Name of interface Ethernet1/1
Hello
object network internal_real
network 192.168.10.0
object network internal_public
host 201.10.10.101
object network external_public
host 201.10.10.100
object network external_internal
host 192.168.10.70
nat (inside,outside) source static internal_real  internal_public destination static external_internal  external_public
access-list OUT-IN extended permit ip host 201.10.10.100  host any
access-group OUT-IN in interface outside
Kind Regards
Paul
