Cannot create EIGRP adjacency over Dynamic Multipoin IPSec VPN
artur.b01
I have Cisco 2811 (Spoke) and cisco ISR4431/K9 (DMVPN Hub). I cannot create EIGRP adjacency between hub and spoke.
Spoke Configuration:
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
crypto isakmp key ******* address 0.0.0.0 0.0.0.0
crypto isakmp invalid-spi-recovery
crypto isakmp keepalive 120 3 periodic
crypto isakmp nat keepalive 30
crypto ipsec transform-set strong esp-3des esp-md5-hmac
mode transport
crypto ipsec profile cisco
set security-association lifetime seconds 120
set transform-set strong
interface Tunnel0
description GRE/IPSEC Tunnel to HUB
ip address 192.168.250.69 255.255.255.0
no ip redirects
ip mtu 1400
ip bandwidth-percent eigrp 1 100
ip hello-interval eigrp 1 30
ip hold-time eigrp 1 90
ip nhrp authentication black
ip nhrp responder FastEthernet0/1
ip nhrp map 192.168.250.1 xx.xx.xx.xx
ip nhrp map multicast xx.xx.xx.xx
ip nhrp network-id 101
ip nhrp nhs 192.168.250.1
ip nhrp registration timeout 30
ip tcp adjust-mss 1360
tunnel source FastEthernet0/1
tunnel mode gre multipoint
tunnel key 150
tunnel protection ipsec profile cisco shared
HUB configuration:
encr 3des
hash md5
crypto isakmp key ******** address 0.0.0.0
mode transport
set security-association lifetime seconds 900
interface Tunnel2
bandwidth 10000000
ip address 192.168.250.1 255.255.255.0
no ip redirects
ip mtu 1400
no ip next-hop-self eigrp 1
no ip split-horizon eigrp 1
ip summary-address eigrp 1 192.168.0.0 255.255.0.0
ip policy route-map Deli_1
tunnel source GigabitEthernet0/0/2
tunnel key 150
I think the configuration is right, becaues router creates an adjacency then falls with error:
Sep 29 12:56:44: %DUAL-5-NBRCHANGE: EIGRP-IPv4 1: Neighbor 192.168.250.69 (Tunnel2) is down: holding time expired
Sep 29 12:58:55: %IOSXE-3-PLATFORM: R0/0: cpp_cp: QFP:0.0 Thread:001 TS:00000045356196197805 %IPSEC-3-REPLAY_ERROR: IPSec SA receives anti-replay error, DP Handle 148, src_addr 118.175.32.229, dest_addr 88.204.160.210, SPI 0x16bf4f54
Please help
5 Replies 5
you could try and configure the below on both routers:
crypto ipsec security-association replay window-size 1024
Thank you Georg for your feedback
I configured crypto ipsec security-association replay window-size 1024 on both router and nothing changed
Log on the hub:
Sep 29 14:59:22: %DUAL-5-NBRCHANGE: EIGRP-IPv4 1: Neighbor 192.168.250.69 (Tunnel2) is down: Interface PEER-TERMINATION received
Sep 29 15:00:14: %CRYPTO-4-RECVD_PKT_INV_SPI: decaps: rec'd IPSEC packet has invalid spi for destaddr=88.204.160.210, prot=50, spi=0x80274BA(134378682), srcaddr=178.135.10.88, input interface=Tunnel2
Sep 29 15:00:19: %DUAL-5-NBRCHANGE: EIGRP-IPv4 1: Neighbor 192.168.250.69 (Tunnel2) is up: new adjacency
Sep 29 15:01:14: %CRYPTO-4-RECVD_PKT_INV_SPI: decaps: rec'd IPSEC packet has invalid spi for destaddr=88.204.160.210, prot=50, spi=0x80374BA(134444218), srcaddr=178.135.10.88, input interface=Tunnel2
floor0-GR2-4431#show ip ei
floor0-GR2-4431#show ip eigrp ne
floor0-GR2-4431#show ip eigrp neighbors | inc 192.168.250.69
floor0-GR2-4431#
Now Hub doesn't have EIGRP adjaceny with remote site
on the ISR, try and remove the invalid spi recovery:
no crypto isakmp invalid-spi-recovery
It feels like the router stops receiving hello messages after a while
balaji.bandi
Is the Tunnel up between Hub and spoke ? Can you post Eigrp config also ?
You need to config eigrp no spli horizon config.
BB
