Cannot enable PIM dense mode on Cisco 3750E SVI
Sam Brynes
I just replaced a failed Cisco 3750G with a Cisco 3750E, and I can't seem to get access to the "ip pim dense-mode" subinterface command. I checked the Cisco feature navigator and tried out these images with no luck:
c3750e-universalk9-mz.122-53.SE2.bin
c3750e-universalk9-mz.150-2.SE11.bin
c3750e-universalk9-mz.122-55.SE12.bin
From the document you linked to -
Note The IP base image contains only PIM stub routing. The IP services image contains complete multicast routing. On a switch running the IP base image, if you try to configure a VLAN interface with PIM dense-mode, sparse-mode, or dense-sparse-mode, the configuration is not allowed.
So you need to have IP Services and you are running IP Base on your switch.
Jon
5 Replies 5
balaji.bandi
Can you post the error and show the version to look?
BB
Hi Balaji,
Sure. I also tried 12.2(58)SE2:
SWITCH(config)#do sh run | i pim
SWITCH(config)#do sh run | i multicast
ip multicast-routing distributed
SWITCH(config)#
SWITCH#config t
Enter configuration commands, one per line. End with CNTL/Z.
SWITCH(config)#int vlan 170
SWITCH(config-if)#ip pim dense-mode
% Invalid input detected at '^' marker.
SWITCH(config-if)#ip pim ?
passive Enable PIM passive interface operation
SWITCH(config-if)#do sh run int vlan170
Building configuration...
Current configuration : 138 bytes
interface Vlan170
ip address 172.17.0.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
snmp ifindex persist
end
SWITCH(config-if)#
sh ver
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 12.2(58)SE2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 21-Jul-11 01:23 by prod_rel_team
ROM: Bootstrap program is C3750E boot loader
BOOTLDR: C3750E Boot Loader (C3750E-HBOOT-M) Version 12.2(44r)SE3, RELEASE SOFTWARE (fc3)
SARCOMERE uptime is 11 minutes
System image file is "flash://c3750e-universalk9-mz.122-58.SE2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: ipbase
License Type: Permanent
Next reload license Level: ipbase
cisco WS-C3750E-48PD (PowerPC405) processor (revision K0) with 262144K bytes of memory.
Processor board ID FDO1446V2A6
Last reset from power-on
7 Virtual Ethernet interfaces
1 FastEthernet interface
52 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 08:17:35:22:58:80
Motherboard assembly number : 73-11174-14
Motherboard serial number : FDO14470CE2
Model revision number : K0
Motherboard revision number : B0
Model number : WS-C3750E-48PD-SF
Daughterboard assembly number : 800-29737-01
Daughterboard serial number : FDO14461G9D
System serial number : FDO1446V2A6
Top Assembly Part Number : 800-28918-04
Top Assembly Revision Number : B0
Version ID : V05
CLEI Code Number : COMCC00ARB
Hardware Board Revision Number : 0x00
Switch Ports Model SW Version SW Image
* 1 54 WS-C3750E-48PD 12.2(58)SE2 C3750E-UNIVERSALK9-M
Configuration register is 0xF
This Cisco doc also discusses PIM on the 3750E series, IOS release 12.2(58)SE:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750e_3560e/software/release/12-2_58_se/configuration/guide/scg3750e/swmcast.html#wp1024278
Jon
Your version does not support what you looking, you need IPSERVICE.
BB
Chris McCann
Did you ever get round this or was it a new switch install ?
