06-13-2016 07:00 AM - edited 03-05-2019 04:13 AM
We have a Cisco 3845 router, which is connected to the uplink(internet) through FastEthernet1/0 Interface. Because we are maximizing bandwidth on this interface, almost 80% I have installed a Cisco Gigabit Ethernet HWIC with ' 1000BASE-T SFP ' in the Wic 0 slot, the item installed looks exactly as shown on this link:
http://www.cisco.com/c/en/us/products/collateral/routers/2800-series-integrated-services-routers-isr/product_data_sheet0900aecd8016be8d.html
Installation of the card was straightforward and smooth. The configs on Fa1/0 and the new GigabitEthernet0/0/0 look as follows
interface GigabitEthernet0/0/0
no ip address
no ip redirects
no ip proxy-arp
shutdown
no negotiation auto
interface FastEthernet1/0
ip address 66.199.39.78 255.255.255.252
no ip redirects
no ip proxy-arp
duplex full
speed 100
I can ping my ' 66.199.39.77 ' gateway no problem when configuration is on Fa1/0, I then remove the ip address on Fa1/0 and shutdown the interface and switch over to Gi0/0/0 interface, assign the same ip address to Gi0/0/0, bring the interface up. I then try to ping 66.199.39.77 but it does not ping. When I run the command:
sh int interface GigabitEthernet0/0/0
It shows that the interface and the link is up, no CRC errors etc... so can't figure out why I cannot ping ' 66.199.39.77 '
So I am not sure if this issue is related to the Wic Card, cabling or some other configuration... any ideas what the issue might be?
Solved! Go to Solution.
06-13-2016 01:44 PM
Thanks for the additional information. The link you give to the forum discussion is interesting and may point to the issue. And it clearly relates to the comment in one of your earlier posts about not having speed or duplex commands for your new interface.
I am thinking about your statement that you are physically moving the cable when you switch interfaces. So it looks like you are connecting an interface that operates only at Gig speed to a device that is almost certainly set for 100 Meg. And that may well be the cause of your problem. I would suggest that you talk with the folks who manage the infrastructure that you are connecting to and ask if they can arrange a connection that would physically be a Gig connection and that is managed to use only 100 Meg.
Rick
06-13-2016 07:56 AM
when you moved to g0/0/0 and the interface came up were you able to ping that ip address .78 locally
whats the port connected to is it a 3rd party device if not and its cisco can you see any layer 1 cdp neighbour ,did you try remove the no negotiation auto and set duplex and speed
did you install the card while the router was powered off
did you capture the output of the show int g0/0/0 when it had the ip address on it
check the arp for that ip is complete as well when on g0/0/0
06-13-2016 08:46 AM
Hello Mark
I did not try that, my bad.
The interface is connected to a 3rd party, its actually in our Datacenter, so the cable goes somewhere to Cogeco infrastructure.... Yes, I have removed the " no negotiation auto " surprisingly did not get the option to set the duplex and the speed for the interface... but after removing the " no negotiation auto " the link came up, with auto negotiation the link was down. But I was not able to ping the gateway....
Yes I have installed the card while the router was powered off
I did not save the capture, but when i run this command everything seemed clean.
I will have to schedule another maintenance window to get more readings... this is our production router so my last window for the maintenance was pretty short...
In your opinion do you think it could be anything associated with Cogeco Infrastructure side? We have a 100Mpbs bandwith, should that also be raised to 1Gbps in order for the new 1G HWIC card to work correctly?
06-13-2016 09:03 AM
Is the Gi0/0/0 connecting to the same provider as FA1/0? If you are not physically moving the cable to make the change but are trusting that Cogeco infrastructure to get the connection then there is some possibility that their infrastructure is not getting you connected correctly.
One thing that I would suggest is to check on how well ARP is working. While you are still connected on FA1/0 do show arp. There should be an entry for the gateway address associated with FA1/0. Then make the change. After the Gi0/0/0 is activated do the show arp. Is there an entry for the gateway address? Is the entry associated with Gi0/0/0? If there is not an entry for the gateway address then I would turn on debug for arp and attempt to ping the gateway address. Check the debug output to see if you are sending arp requests and what kind of response you are getting.
Rick
06-13-2016 10:21 AM
Hello Richard
Yes the Gi0/0/0 is connecting to the same provider as FA1/0, I am actually physically moving the cable over to Gi0/0/0 when making the switch over.
I just did a ' show arp ' while the cable is connected to FA1/0 and got this result:
Internet 66.199.39.78 - 0017.e059.a7d1 ARPA FastEthernet1/0
To check what the arp would look like when connected to Gi0/0/0 i would have to schedule another downtime window....
Also, i came across this post and wander if this is the issue that i am facing:
https://supportforums.cisco.com/discussion/12323826/no-speed-or-duplex-commands-available-after-installing-hwic
Could it be the rate limit issue? the HWIC card operates at 1Gbps, full duples while the actual bandwith to Cogeco operates at 100Mpbs?
06-13-2016 01:44 PM
Rick
06-15-2016 11:55 AM
Hi Richard, so I got in touch with Cogeco DC, they have confirmed that our 1Gbps card will not work with their end, as on their end we are hardcoded to a 100Mbps hardware. We have submitted an order to connect us to 1G port with burstable bandwith.
06-15-2016 12:17 PM
Thanks for the update. I am glad that my suggestion about the possible cause turned out to be correct. Thank you for using the rating system to mark this question as answered. I am optimistic that when they have changed their end to be burstable and capable of up to a Gig speed that it will work as you need it to.
Rick
07-05-2016 10:47 AM
Yes you were %100 correct. Cogeco has made the change on their end and the interface is working perfect now.
Thank You again.
07-07-2016 08:04 AM
Thank you for posting back to the forum to confirm that my suggestion was correct and to let us know that the problem is now solved and the interface is working perfect now.
Rick
