Cannot Load the IOS of a 7206vxr Router
I want to change the IOS of my Cisco7206vxr Router which have a NPE-G2 installed in it.I want to change the IOS to c7200p-ipbase-mz.124-15.T7.bin . But after I upload the new file into the router the router continiously saying the following error messages :-
%SYS-6-BOOT_MESSAGES: Messages above this line are from the boot loader.
loadprog: bad file magic number: 0x0
boot: cannot load "cisco2-C7200"
System Bootstrap, Version 12.4(12.2r)T, RELEASE SOFTWARE (fc1)
Copyright (c) 2006 by cisco Systems, Inc.
Socket jumper: not present Failsafe jumper: present = normal
FPGA revision 0x00000026
C7200 platform with 2095104 Kbytes of main memory
Readonly ROMMON initialized
boot: cannot load "disk2:c7200p-ipbase-mz.124-15.T7.bin"
string is disk2:c7200p-ipbase-mz.124-15.T7.bin
boot: cannot load "disk2:"
Lastly the prompt which I am getting is Router(boot)>.
What is the actual problem and how can it be solved.
Any help is most welcome.
Abhishek Pal
paolo bevilacqua
Is disk2 right? Probably not.
Check and reset boot variables as needed: "env" "BOOT=xxxx", etc.
Formatting bootflash: and disk2: and then re-transferring the boot image and IOS resolved the issue.
Thanks and regards.
Abhishek
shivlu jain
Level 5
Level 5
hi
try to use "tftpdnld -r" in rommon mode. It will upload the ios in ram. Because the problem you are facing most probably with the bad flash or try to format it.
regards
shivlu jain
