cannot login with ssh from network
Daniel Jansma
this 877 is configured like this:
Current configuration : 1953 bytes
version 12.4
no service pad
service password-encryption
hostname Vitamine-ADSL-VoIP
boot-start-marker
boot-end-marker
enable secret 5 $1$aWuV$JUjVoy./Y2XTl.Hv9ZJwh/
no aaa new-model
dot11 syslog
ip cef
ip name-server 213.144.235.1
ip name-server 213.144.235.2
username admin privilege 15 secret 5 $1$y/XI$FkVttFvlDNwaloHpIr6Vu/
archive
log config
  hidekeys
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
pvc 0/33
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
ip address 192.168.100.253 255.255.255.0
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
interface Dialer1
mtu 1492
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap callin
ppp pap sent-username kpfgfd2841mc0 password 7 115E404455428402152212F19
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
no ip http secure-server
ip dns server
ip nat inside source list 101 interface Dialer1 overload
access-list 23 remark acl_remote_management
access-list 23 permit 95.142.48.239
access-list 23 permit 84.246.5.4
access-list 23 remark acl_remote_management_routit
access-list 23 permit 84.246.25.0 0.0.0.255
access-list 23 permit 172.31.255.0 0.0.0.255
access-list 23 permit 212.121.121.0 0.0.0.255
access-list 101 permit ip 192.168.100.0 0.0.0.255 any
dialer-list 1 protocol ip permit
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
end
So, when i try to connect with my laptop with ip 192.168.100.100 it says connection refused!
Hope someone can help :-)
Richard Burts
The issue is that your vty are configured to use access list 23 to control remote access. And access list 23 does not permit 192.168.100.100. Add a permit in access list 23 or remove access-class from the vty and then your SSH could work.
Rick
Rick
Richard Burts
Rick
Rick
Thanks, first i needed tot create a rsa key for ssh version 2.0
Yes I had wondered if the RSA key might be an issue. But clearly the primary problem was the access list 23. I am glad that my suggestion was helpful in getting your problem solved. Thank you for using the rating system to mark this question as answered.
Rick
Rick
