Highlighted
Beginner
Cannot ping my clients pppoe with ACL nat active
I have a VXR7206 NPE-G2 router running as a PPPoE server. My lan network is 172.16.99.0/24, and after creating access-list 1, I lost the ability to ping the lan network from outside the Router. I only have this acces-list, and when I delete it the ping to Lan network from outside the router works normally.
Thanks in advance!!
interface GigabitEthernet0/1
description LINK
ip address X.X.220.158 255.255.255.252
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
media-type rj45
negotiation auto
ipv6 address X:X:5E00::F2/124
ipv6 enable
interface GigabitEthernet0/2
description ***LAN_PPPOE***
duplex auto
speed auto
media-type rj45
negotiation auto
ipv6 enable
ipv6 nd managed-config-flag
ipv6 dhcp server PPPv6 rapid-commit
pppoe enable group clientes
interface Virtual-Template1
mtu 1492
ip unnumbered Loopback0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
no ip route-cache
ip nat inside source list 1 interface GigabitEthernet0/1 overload
access-list 1 permit 172.16.99.0 0.0.0.255
1 ACCEPTED SOLUTION
Highlighted
Hi Dirlie,
Instead of using standard access-list 1, use an extended ACL that only matches on your Internet traffic to get NATTED. Use something like
access-list 199 deny ip 172.16.99.0 0.0.0.255 10.0.0.0 0.255.255.255
access-list 199 deny ip 172.16.99.0 0.0.0.255 172.0.0.0 0.31.255.255
access-list 199 deny ip 172.16.99.0 0.0.0.255 192.168.0.0 0.0.255.255
access-list 199 permit ip 172.16.99.0 0.0.0.255 any
and Change your NAT rule to
ip nat inside source list 199 interface GigabitEthernet0/1 overload
Star me if you think this is helpful.
Sebastian
3 REPLIES 3
Highlighted
Hi Dirlie,
Sebastian
Highlighted
VIP Expert
what if you just exclude ICMP from being translated ?
access-list 101 deny icmp any any echo
access-list 101 deny icmp any any echo-reply
access-list 101 permit ip 172.16.99.0 0.0.0.255 any
ip nat inside source list 101 interface GigabitEthernet0/1 overload
Highlighted
VIP Mentor
Hello
Are you missing something off your post? - The only acl i see relates to an ipv4 subnet and NAT but I dont see any nat applied to your lan interface or any ipv4 addressing?
The virtual temple isnt doing anything as far as I can see and it has the wrong nat applied to it anyway.
kind regards
Paul
Please rate and mark posts accordingly if you have found any of the information provided useful.
It will hopefully assist others with similar issues in the future
Content for Community-Ad
